RoseMary30
Settling in
Setting up hub
Just got my new hub and setting up my internet. There is a Technetix TRIS-1002l which is connected from the main wall into the TiVo box but not anywhere for me to put the new cable for the isolator cable. Do i need to buy a spliter or is it missing from broadband kit I just recieved?
  • 13.24K
  • 1.01K
  • 3.08K
Re: Setting up hub
afaik thats an isolator - i thought they supplied a splitter if you needed one - its not clear what you are doing - does the tivo exist and you are addin BB
you dont need to buy one - give them a ring and they should send one or wait here and VM should be able to sort it
____________________
Tony
  • 4.74K
  • 319
  • 796
Roger_Gooner
Superstar
Re: Setting up hub
You should be able to connect the isolator cable to the Technetix, it's a push fit. The splitter would be for a V6 or TiVo box if you subscribed for TV.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
