  • 12
timedout
Message 1 of 7
v6 box internet connection
 I have just got a new V6 box.  I have V6 in one room, Tivo in another and PC in a third.  The internet connection to the PC keeps breaking and staying disconnected for about a minute and then reconnecting.  My landline also goes off at times.  When I ring Virgin they say everything is fine.  Help, I know nothing about tech.
  • 8.24K
  • 847
  • 1.28K
Message 2 of 7
Re: v6 box internet connection
Which model of Hub do you have (printed on a sticker on the base or side)?
How are you connecting all of these devices - wifi or ethernet cable.  If wifi what is the connection like on the PC connected by ethernet cable ?  The fact that the landline is going down as well does suggest its a network connection problem though.
  • 12
timedout
Message 3 of 7
It is a version 3.0.  The hub is in the lounge.  The Ethernet cable for the PC is from a port in another room to the hub.  Sorry, I am really clueless with all of this. We didn't have any problems until we received the new gear a couple of weeks ago.
  • 12
timedout
Message 4 of 7
It is the PC that uses the Ethernet cable that keeps going down.
  • 8.24K
  • 847
  • 1.28K
Message 5 of 7
Ok - if that is going down and the phoe is faulty too, you really need to report the fault to CS - have you called it in ?
In the meantime you could post up your Hub network stats on here so people can see if there is a network connection issue.  Hopefully these instructions are simple enough.
if you could go to http://192.168.0.1  (or http://192.168.100.1 ) in your browser [there is no need to login] and then click on the  “router status” icon at  top right - or bottom middle - of first page up -- depending on which hub you have  and then copy/paste 3 sets of data onto here - the downstream, upstream , &  network logs.  Don't worry about the formatting it can be easily read (by others & not by me!), but try and avoid using screen shots & don’t include personal data or mac addresses.
Here is an example of how they should appear
https://community.virginmedia.com/t5/Networking-and-WiFi/Superhub-3-0-Overheating/td-p/3816312
If there looks to be a network connection problem, a VM Forum staff member on here will organise a technician visit or you may be quicker calling the help line for that.
  • 12
timedout
Message 6 of 7
Someone called 'Collie' in the community had the same problem in January.  It seemed to go on for a while and ended with them having a technician out - but after that it doesn't say what they did.
I have just had another disconnection - this is what the message says:
There is no Internet Connection
Try:
  • Checking the network cables, modem, and router
  • Reconnecting to Wi-Fi
ERR_INTERNET_DISCONNECTED
  • 8.24K
  • 847
  • 1.28K
Message 7 of 7
Call in the fault and see what they say.
