  • 29
mitch661
diagnostics hub3
hi, since install testing results always have red broadband triangle exclamation mark.
home set up problem?
  • 2.78K
  • 139
  • 405
jpeg1
Trouble shooter
Re: diagnostics hub3
Can you be a bit more specific?  What tests are you trying and what messages do you get with the symbols?
Have you actually got a working broadband connection?
  • 29
mitch661
internet working. the test is logging in to router test via Mac address.
it runs green circle and shows red exclamation mark bb, WiFi yellow tick ,Ethernet yellow tick.
then warns home network has problems.
thanks Chris.
