Rubooski
Wifi issues
I'm having some strange issues with my router.
When it's turned on there is no wifi led flashing, however if I turn it on without the data cable connected the wifi works fine.
I have tested the ethernet connection as well and there is no joy either.
Is there something wrong with the router?
Many thanks in advance for any help.
  • 10.3K
  • 642
  • 1.36K
jb66
Re: Wifi issues
It could be a faulty ethernet cable or device connected via ethernet.  Something is crashing the box
Rubooski
Re: Wifi issues
Its the same result when the ethernet cables are disconnected.
The only time the wifi is flashing is when the main cable is unplugged.
It's a superhub 2
  • 11.7K
  • 347
  • 678
Forum Team (Retired) Samantha_L
Re: Wifi issues
Hello Rubooski,
Welcome to the community. It's nice to have you here.
My apologies you are experiencing a problem with the router.
If you are still having this issue, can you please send me a PM with your name, confirm if you are the account holder and full address. As I was unable to find your account to run some line tests.
Sam
