  • 12
Lstedman
Message 11 of 24
Re: WiFi dropping out every few hours
I keep getting a failure to open page message when trying to go on the http://192.168.0.1 link, it just loads for a minute then crashes, is there another way to access?
The powerlines are all using the same SSID yes. I will try and separate them if I can work out how!
  • 7.86K
  • 815
  • 1.22K
Message 12 of 24
Try with an ethernet cable connecting from laptop/pc direct into the Hub. Try a different browser.
  • 12
Lstedman
Message 13 of 24
Tried a different browser, different computer, and direct ethernet connection.
I will shortly be throwing the hub out of the window!
  • 7.86K
  • 815
  • 1.22K
Message 14 of 24
Mmmm.. dont really know what to suggest.
I use 192.168.100.1 as mine is in modem mode.
Perhaps try again reboot the Hub, and clear your browser "cache" first and then omit the http:// - just type in the URL box 192.168.0.1
  • 12
Lstedman
Message 15 of 24
Nope nothing is loading the page. Have also reset it on the back of the router as I saw suggested elsewhere, still nothing.
Very frustrating. I assume even if I got another router I would not be able to change the relevant settings to put it into modem mode anyway now that I can't access the page! Back to square one!
  • 7.86K
  • 815
  • 1.22K
Message 16 of 24
You could try calling it in as a fault they are usually able to access the Hubs settings
  • 7.86K
  • 815
  • 1.22K
Message 17 of 24
Another thought after you do the factory pinhole reset did you restart the box - as they say to do?
If so try it again this way - it has worked for some previously..
With the Hub "on" - push in the pin on the back/side/bottom of the Hub with the end of a paperclip until you feel it at the “stop point” and hold it there for a "timed" 60 seconds do NOT restart the Hub after that.
See if that shifts it !
  • 12
Lstedman
Message 18 of 24
Finally got into the router settings after another pinhole reset without restarting the router and here are the results...
1299000000437256 qam21
21390000007.438256 qam1
3147000000738256 qam2
41550000006.638256 qam3
51630000006.838256 qam4
61710000006.638256 qam5
71790000006.538256 qam6
81870000006.338256 qam7
9195000000638256 qam8
102030000005.938256 qam9
112110000005.538256 qam10
122190000005.338256 qam11
132270000004.937256 qam12
142350000004.537256 qam13
152430000004.138256 qam14
16251000000438256 qam15
172590000003.937256 qam16
182670000003.938256 qam17
19275000000438256 qam18
202830000003.938256 qam19
212910000003.737256 qam20
22307000000438256 qam22
23315000000438256 qam23
24323000000437256 qam24
1Locked37.660
2Locked38.660
3Locked38.660
4Locked38.650
5Locked38.9200
6Locked38.6140
7Locked38.630
8Locked38.950
9Locked38.640
10Locked38.650
11Locked38.650
12Locked38.650
13Locked37.660
14Locked37.650
15Locked38.600
16Locked38.600
17Locked37.600
18Locked38.650
19Locked38.640
20Locked38.650
21Locked37.6130
22Locked38.660
23Locked38.650
24Locked37.650
  • 12
Lstedman
Message 19 of 24
1462000004.025512064 qam37
2326000003.975512064 qam39
3394000004.05512064 qam38
4603000004.2512064 qam40
3ATDMA0000
4ATDMA0000
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2019 03:24:42ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/04/2019 08:44:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2019 21:31:53ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/04/2019 02:00:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2019 11:54:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2019 10:15:5ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2019 19:19:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 03:54:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 07:33:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2019 15:00:6ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2019 02:05:18ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2019 11:32:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/05/2019 08:12:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/05/2019 16:58:11Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:29Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 12
Lstedman
Message 20 of 24
Now wondering if this could have anything to do with new neighbours across the road having Virgin installed a few weeks ago?
