  • 5
Message 1 of 11
Very slow speed even on wired connectivity
i have got 350 mbps broadband but i hardly get 150 mbps and sometimes like 50-90 mbps and tats on wired. even wireless devices right next to the router speed is slow.
hub has been rebooted several times even factory reset it but no luck. i see yellow light. there is no micowave or any other device that would block the signals.
i ran checks and it says there are some faults with phone line.
virgin media call center is closed so what option have we got?
Tags (1)
  • 12K
  • 934
  • 1.53K
Message 2 of 11
Re: Very slow speed even on wired connectivity
Then
Can you please
Mike Robinson
  • 24.89K
  • 1.44K
  • 3.17K
Message 3 of 11
90Mbps on a wired device would indicate either a CAT5 cable or a device with only a 10/100Mbps network port.
What are you speedtesting with when wired?
  • 5
Message 4 of 11
fast.com
speedtest
  • 24.89K
  • 1.44K
  • 3.17K
Message 5 of 11
@stariq2020 wrote:
fast.com
speedtest
From what device?
  • 5
Message 6 of 11
laptop
android phone
  • 24.89K
  • 1.44K
  • 3.17K
Message 7 of 11
Ok work with me a bit here...
What is the make and model of the laptop?
Are you wiring direct to the hub with it?
If so what spec is the cable being used - it will be printed in the side of the cable and will say “CAT” followed by a number and maybe a letter.
  • 5
Message 8 of 11
dell inspiron 7537
CAT 5E
  • 24.89K
  • 1.44K
  • 3.17K
Message 9 of 11
And what speed are you achieving when wired? Do a speedtest on speedtest.net and link back the "share" URL for the result
  • 5
Message 10 of 11
