Ports are not forwarding
I have already tried many thing in order to get this working like factory resetting my router but i still can't get these ports (8888 and 3000) open. i am trying to open them to my raspberry pi so there shouldn't be a firewall on my device. I have successfully opened port 22 for ssh and can connect through that port but any other port i try it doesn't want to work.
I have used https://canyouseeme.org/ to check the ports.
My settings:
Tags (3)
  • 14.76K
  • 621
  • 1.42K
Re: Ports are not forwarding
Maybe ports 8888 and 3000 are UDP so port tester only test TCP.
  • 116
  • 11
  • 29
Are you certain that your pi is actively listening on those ports?
netstat -an | grep 3000
( or 8888 ofc ;))
Thanks for the pointers, for some reason my express api server was listening to a different port that i set but fixed that now.
Also i found that this command worked better for seeing active ports: sudo lsof -i -P -n | grep LISTEN
sorry for the late reply as well
  • 116
  • 11
  • 29
netstat -an | grep LISTEN would give you the same
lsof is for seeing what files are "open" but that will include network ports  🙂
whatever works though 🙂
Ok, thanks for the help
