AmateurIOT
  • 11
Message 1 of 7
Is it my cable modem... I think it is... and how do I get it changed?
A quick history of my setup...
I've recently changed my entire network over to a Unify system after suffering all kinds of issues with a Tp-Link system (the Super-Hub 2 just wasnt cutting it as I have in excess of 50 devices connected to the network).
I had issues over the new year (I had no connection at all on the modem for 8 days!!) and that was the final straw for me... TP-Link OUT Unifi IN! but in the back of my mind was the question "was it the modem?". Also I know that virgin uses VOIP for their phone and I'm getting a crackly line (normally this means I'll get issues soon... 😓)
Today (in fact just under an hour ago) I had a system crash and while the unify system was still running. I did a test (on my 4G mobile) I got the "theres an issue book an engineer" mesage, it was at this point I reset the cable modem (virgin) and BINGO internet was back up! At no point did the lights on the super-hup change colour, they've always been dark blue (as they should be).
I'm a complete novice to networking but love to tinkerand and the more and more I think about it I'm left wordering "was it the modem all along?"
Can someone have a look at my logs from the modem and advise me please?
Just taken off the modem within the last 30 mins
Cable Modem Status
Item
StatusComments
Acquired Downstream Channel (Hz)138750000Locked
Ranged Upstream Channel (Hz)53700000Success
Provisioning StateOKOperational
Upstream
US-1US-2US-3US-4
Channel Type2222
Channel ID2431
Frequency (Hz)53700000394000004620000060300000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)43434343
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts0000
T4 Timeouts0000
Downstream
DS-1DS-2DS-3DS-4DS-5DS-6DS-7DS-8
Frequency (Hz)138750000146750000154750000162750000170750000178750000186750000194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9526.9526.9526.9526.9526.9526.9526.952
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)6.416.366.46.316.36.196.035.81
RxMER (dB)37.9438.2638.2638.2638.6138.9838.9838.26
Pre RS Errors284352288277270290298287
Post RS Errors279304287277270284298274
Thankfully its the 1st time since switching over to Unify and was relieved it wasnt their kit. (PHEW!)
Many thanks
  • 20.51K
  • 2.18K
  • 3.62K
Message 2 of 7
Re: Is it my cable modem... I think it is... and how do I get it changed?
Stats look ok - post up the Network Logs as well.
Also, in the meantime... If you haven’t already, set up a free and secure “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
AmateurIOT
  • 11
Message 3 of 7
Sorry I though i did those...
First Time
Last TimePriorityError NumberDescription
21/02/2021 15:41:19 GMT21/02/2021 15:41:19 GMTWarning (5)66050310Auth Success - Web login successful.
21/02/2021 15:35:15 GMT21/02/2021 15:35:15 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
20/02/2021 09:44:30 GMT20/02/2021 09:44:30 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
20/02/2021 09:44:30 GMT20/02/2021 09:44:30 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
17/02/2021 04:06:05 GMT17/02/2021 04:06:05 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
17/02/2021 04:06:05 GMT17/02/2021 04:06:05 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
14/02/2021 05:49:14 GMT14/02/2021 05:49:14 GMTError (4)68000407TOD established
13/02/2021 02:22:50 GMT13/02/2021 02:22:50 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
13/02/2021 02:22:50 GMT13/02/2021 02:22:50 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
09/02/2021 23:12:04 GMT09/02/2021 23:12:04 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
09/02/2021 23:12:04 GMT09/02/2021 23:12:04 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
07/02/2021 05:50:31 GMT07/02/2021 05:50:31 GMTError (4)68000407TOD established
05/02/2021 16:33:21 GMT05/02/2021 16:33:21 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
05/02/2021 16:33:21 GMT05/02/2021 16:33:21 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
02/02/2021 04:33:21 GMT02/02/2021 04:33:21 GMTNotice (6)68010600DHCP Renew - lease parameters tftp file-******** modified
02/02/2021 04:33:21 GMT02/02/2021 04:33:21 GMTError (4)68010300DHCP RENEW WARNING - Field invalid in response v4 option
31/01/2021 23:16:37 GMT31/01/2021 23:16:37 GMTCritical (3)82000200No Ranging Response received - T3 time-out
AmateurIOT
  • 11
Message 4 of 7
just gone down again. this time i was unable to access the cable modems IP address until i reset it
First Time
21/02/2021 16:33:34 GMT21/02/2021 16:33:34 GMTError (4)68000407TOD established
  • 20.51K
  • 2.18K
  • 3.62K
Message 5 of 7
If its going down on an ethernet connection the BQM should record that. It wont report wifi drops.
Try the 0800 561 0061 number to see if there are any known issues in your postcode.
  • 7.94K
  • 636
  • 1.38K
Message 6 of 7
What Unifi equipment are you using? Are you running the Unifi “Network Comtroller” software, this provides lots of helpful information about your system setup. I have a lot of experience with Unifi USG, UDM Pro, Cloud Key 2+, Protect and camera, USW and UAPs.
AmateurIOT
  • 11
Message 7 of 7
I have a USG with cloud key attached, a central 8 port switch with 3 links going to 5 port switches (all netgear gigabit) and 2 APs.
I did check the controller logs but nothing was listed but do get latency issues reported sometimes over WiFi (typical figures are 30-60, my TP-LINK reported over 100 a little too often for my liking). Also is wasn't the WiFi going down but the whole network, cabled connections were offline too.
I changed the network link from modem to USG with a new cat6 one when I changed the system over to unifi (I'm fact I changed ALL the cabling to cat6) as some of the cat5 was definitely getting past its use by date.
The thing that makes me feel its the modem is when I power down (just the modem) then power back up everything is OK... Its only done it twice today and since changing over to unifi this is my only occasions. But in the past my kids would sometimes have to reset everything (modem and tp link gear) 2-3 times a day.
