MRSATKINS
Message 1 of 7
Intermittent Connection Issues
I've been experiencing intermittent connection to my wifi for the past few weeks.  I did speak to a member of Virgin's technical support team who managed to get my connection working - however it's dropping out several times a day now.  I obviously can't spend every moment that it decides not to work on the phone trying to sort it out (and also there's the issue that it's intermittent and will reconnect).  Is this a widespread issue?  Is there something else that I need to do?  Do I need new equipment?  HELP! 🙂
  • 19.22K
  • 1.68K
  • 4.22K
Message 2 of 7
Re: Intermittent Connection Issues
Would need to check the signal levels if could go to http://192.168.0.1 or if using modem mode http://192.168.100.1 clicking router status top right or bottom of page depending on hub [no need to login - depending on hub] and if could copy/paste the downstream, upstream, network log, don't worry about the formatting we can easily read it.. try and avoid using screen shots..
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
MRSATKINS
Message 3 of 7
P.S.  I think I've accidentally marked this as solved - but it isn't
  • 1.06K
  • 38
  • 51
Message 4 of 7
Hi MRSATKINS
Welcome to our community forum pages and thank you for posting.
We are sorry to hear that you have been experiencing ongoing issues with your WiFi service.
Do you use any WiFi boosters at all?
Do you have any issues when using devices over a wired connection?
David_Pn
Need help changing SIM card? Find out more about activating your 4G ready SIM. 4G SIM Swap Help
MRSATKINS
Message 5 of 7
Hi David
Thanks for your reply.  I don't use a booster and don't think that I need one in all honesty - this wasn't an issue initially and nothing has changed with regards to the placement of any of my equipment.  I'd been asked for downstream, upstream and the network log - I did reply to that message however it appears that it didn't send because it exceeded your maximum amount of characters - I'll try and do this in a couple messages and hopefully you'll make sense of it all 🙂
1299000000-0.538256 qam21
2139000000-0.238256 qam1
3147000000-0.240256 qam2
4155000000-0.440256 qam3
5163000000-0.440256 qam4
6171000000-0.238256 qam5
7179000000-0.238256 qam6
8187000000-0.238256 qam7
9195000000-0.238256 qam8
10203000000-0.240256 qam9
11211000000-0.440256 qam10
12219000000-0.440256 qam11
13227000000-0.538256 qam12
14235000000-0.738256 qam13
15243000000-0.740256 qam14
16251000000-0.740256 qam15
17259000000-0.740256 qam16
18267000000-0.740256 qam17
19275000000-140256 qam18
20283000000-140256 qam19
21291000000-0.938256 qam20
22307000000-0.740256 qam22
23315000000-0.740256 qam23
24323000000-0.540256 qam24
1Locked38.9144148
2Locked38.611487
3Locked40.311077
4Locked40.3100111
5Locked40.3121147
6Locked38.911697
7Locked38.99779
8Locked38.910781
9Locked38.911886
10Locked40.311486
11Locked40.388160
12Locked40.39273
13Locked38.97685
14Locked38.910796
15Locked40.3130108
16Locked40.3100105
17Locked40.3116207
18Locked40.97893
19Locked40.311397
20Locked40.314183
21Locked38.9110206
22Locked40.39297
23Locked40.397107
24Locked40.315688
1258000003.825512064 qam12
2326000003.825512064 qam11
3394000143.825512064 qam10
4462000003.825512064 qam9
MRSATKINS
Message 6 of 7
(see previous message for other data and explanation)
3ATDMA0000
4ATDMA0000
19/04/2019 09:11:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2019 09:11:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/04/2019 10:34:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/04/2019 20:42:34ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 19:24:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 19:26:40ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 19:29:23ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 19:29:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2019 19:58:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2019 23:39:19ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2019 00:34:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2019 13:18:51ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2019 02:58:28ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2019 02:58:28noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/04/2019 22:18:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/05/2019 16:34:46ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2019 15:55:38ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/05/2019 15:55:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2019 15:20:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2019 18:16:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 1.06K
  • 38
  • 51
Message 7 of 7
I'd like to access your account to take a closer look on there if that's OK?
I'll send you a private message in a moment to get some account details from you.
David_Pn
