  • 6
lil_bugga
Message 1 of 9
Incorrect location settings wifi only
Since having our WiFi router changed our household location is miles off. On my phone if I disconnect from the WiFi my location is correct.
This issue has only occurred since the replacement route, the old one didn't have this problem.
I't's a nuisance when using location based apps. How do we rectify this issue?
  • 3.4K
  • 191
  • 549
chenks
Wise owl
Message 2 of 9
Re: Incorrect location settings wifi only
i assume it's an android phone?
it'll correct itself over time once the database realises your new SSID is at your location.
mine took about 3-4 weeks when i moved and took my AP with me.
for weeks it kept defaulting back to my old location.
  • 6
lil_bugga
Message 3 of 9
It is android, yes.
Why does swapping from 1 hub to another through out location. I thought location info was sent to the router based on the area of the country which hasn't changed.
Really don't want to wait weeks for it to fix itself, it doesn't help when trying to check location/distance of ebay items or using dating apps.
Will have to use 4g instead if that's the case
  • 26K
  • 1.1K
  • 4.23K
Message 4 of 9
ip addresses and routers do not have a location. There is no way any site can know this without being hold.
They are worked out based on 3rd party databases that are often wrong.
if you need good location you need to use GPS not wifi/ip based locations
  • 6
lil_bugga
Message 5 of 9
So if this data is stored on 3rd party databases then a change of router shouldn't have changed my location which is what's happened.
  • 11.79K
  • 1.08K
  • 2.55K
griffin
Message 6 of 9
The change of router would have changed your IP address.
  • 5.22K
  • 719
  • 1.46K
teabag
Superstar
Message 7 of 9
A change of router would have changed your IP address, the 3rd party sites (Google ect) will be using the last know location of that IP, in time they will catch up with your location.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
  • 3.4K
  • 191
  • 549
chenks
Wise owl
Message 8 of 9
exactly. as i said in my first reply, give it time and it'll correct itself
for 3 weeks mine kept defaulting back to my old location about 20 miles away.
once i moved to the window though it always jumped back to the correct location.
  • 2.74K
  • 138
  • 386
jpeg1
Trouble shooter
Message 9 of 9
On the other hand, you may not want the whole world to know your location.
