Hub 5 disconnect
dan37167
Hub 5 disconnects every 2 hours no light no signal no WiFi. I have to press bottom to restart it every time when it stops working.
1 REPLY 1
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
