  • 78
  • 8
Message 1 of 10
Hub 4 modem mode
Hi all just a quick question, when in modem mode does the hub 4 only have one functioning ethernet port?
I'm using a Deco mesh system and it's all working fine but could really use another network port.
Thanks.
  • 24.97K
  • 1.44K
  • 3.18K
Message 2 of 10
Re: Hub 4 modem mode
Thanks.
Yes. You’ll need to attach an unmanaged desktop switch to the deco’s spare LAN port to get more Ethernet connectivity.
  • 78
  • 8
Message 3 of 10
Thanks for that.  If you're familiar with the TP Link Deco mesh, please could you confirm if this setup will work? (Sorry for the crude drawing)
  • 24.97K
  • 1.44K
  • 3.18K
Message 4 of 10
The switch needs to connect to the deco, not the hub.
So Unit 1 would connect to the hub (and only that unit would connect to the hub). The switch needs to connect to Unit 1 and everything else can then be connected to the switch.
  • 78
  • 8
Message 5 of 10
As this is my current setup, but the speed is not good enough to the PC upstairs you see.
  • 78
  • 8
Message 6 of 10
Cool, so this would be the right configuration then?
  • 24.97K
  • 1.44K
  • 3.18K
Message 7 of 10
Yes that would work. But powerlines will be slower due to interference and rely on being in the same ring main.
  • 78
  • 8
Message 8 of 10
Bugger. Don't think they're on the same ring main.
  • 24.97K
  • 1.44K
  • 3.18K
Message 9 of 10
Is the deco unit not in the same room as the PC? Or could it be? And you can wire to the deco with the PC.
  • 78
  • 8
Message 10 of 10
Yeah yeah, that's the setup I have now.  Main Deco downstairs hooked up to VM modem, then two upstairs in each bedroom.
Wireless speed from main deco unit 1 downstairs is 150 to 200 meg - No problem with that
Wireless speed from deco unit 2 upstairs is around 60 to 100meg - No problem with that
Wireless and wired speed from deco unit 3 (with the PC connected) upstairs is like 7 to 15 meg - Where the issue lies. The PC is connected to the deco with ethernet cable, but wireless speed in that room is also rubbish.
