  • 6
MrABBA
Message 1 of 19
Hub 3 thinks its a sky router
 We had a power cut yesterday and it came back on fine after that but when i went to use the internet this morning i was greeted to a sky 'your connection has dropped' page. i am connected straight to the hub with an ethernet cable. i mentioned it when i rang 150 to tell them we had no internet and the lady on the other end of the phone had no idea what i was on about. i have no idea why this would happen.sky router 1.pptx.jpg
  • 5.68K
  • 437
  • 944
Hero
Message 2 of 19
Re: Hub 3 thinks its a sky router
Has your machine also got a WiFi connection? I should power off you hub leave for a few minutes and then power on again, might fix the problem.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
  • 6
MrABBA
Message 3 of 19
no my computer doesn't have wifi. i unplugged it and plugged it back in when i was on the phone to 150 but it still thinks were on sky, even speedtest.net says we are.
  • 10.87K
  • 406
  • 1.24K
Forum Team (Retired) Nicola_C
Message 4 of 19
Hello MrABBA
How intriguing, do you have a Sky broadband connection available in the house or I wonder perhaps if the page was cached on the computer, did you used to have Sky at one time. It may also be worth checking the computer for any installed Sky programs.
Thank you
Nicola
Virgin Media Forum Team
  • 6
MrABBA
Message 5 of 19
We had sky broadband about 6 years ago but the computer i was seeing it on is only 1 year old so has never been on sky.
  • 11.58K
  • 1.06K
  • 2.49K
griffin
Message 6 of 19
Are tou using powerline adapters at all?
  • 3.94K
  • 261
  • 651
Roger_Gooner
Community elder
Message 7 of 19
Reset the hub with a paper clip to press the pinhole reset button for 20 seconds.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 1.4K
  • 107
  • 266
stevedh2
Knows their stuff
Message 8 of 19
Wow that's interesting problem.
and I checked the date and it isn't 1st April.
And do you still have this problem after a week..
so
There is no way that web page is comming from your Virgin Hub (I assume it does say virgin on the side and not sky).
You're not using Wifi so haven't inadvertently hijacked a neighbours internet via wifi.
If you're using powerlines then it is possible you have hijacked theirs via those, if so try a direct ethernet connection.
Try switching off the superhub, do you still get that page.
are you sure this i'snt a wind up?
what happens if you click on 'lets fix it'
with it switched off try pinging 192.168.0.1
try typing 'tracert 192.168.0.1' at your command line. (with it off and with it on).
try using a different browser.
do you also get this when using a phone or another computer.
  • 6
MrABBA
Message 9 of 19
i am connected directly into the router using an Ethernet cable. I still get the page after i leave it unplugged for 10 minutes. If i press lets fix it it says 'ERROR 401 access denied'. It happens on all of the devices in the house WiFi and Ethernet.
  • 6
MrABBA
Message 10 of 19
I tried that, It didn't help.
