on 03-01-2021 20:29
Over the past one week my Hub 3 has been constantly rebooting. Specially starts at 4pm everyday. The wifi is intermittently every hour.
I've tried reset the Hub, still no fix. Possibly trying a new hub would help. Can any forum team members help me? I need an technician.
Thanks for the attention.
on 06-01-2021 22:16
Who can help
on 06-01-2021 22:27
@TumblerHen wrote:Who can help
The HUB stats are all over the place so you clearly have an issue in the local area or with your specific connection:
You need to report it to VM. Either:
on 10-01-2021 11:36
07/01/2021 20:46:40 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:46:18 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:46:18 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:45:54 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:45:22 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:44:47 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:44:41 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:44:25 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:44:4 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:44:2 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:43:56 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:43:12 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:43:10 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:43:0 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:39:19 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:39:2 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:38:26 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:38:22 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:38:22 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/01/2021 20:35:29 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 10-01-2021 20:06
10/01/2021 20:04:29 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:55:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:40:53 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:39:35 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:37:23 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:29:59 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 19:14:19 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 18:43:58 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 18:43:17 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 18:16:14 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:51:34 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:47:44 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:47:43 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:46:24 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:36:43 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:29:1 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:27:39 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:27:21 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:17:57 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/01/2021 17:12:11 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 10-01-2021 20:07
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | xv9873254k;fg87dsfd;kfoA,.iye |
SFID | 16560 |
Max Traffic Rate | 230000061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
Primary Upstream Service Flow
SFID | 16559 |
Max Traffic Rate | 22000061 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
on 10-01-2021 20:08
1 | 331000000 | 13.4 | 34 | 256 qam | 25 |
2 | 267000000 | 12.1 | 34 | 256 qam | 17 |
3 | 275000000 | 12.3 | 34 | 256 qam | 18 |
4 | 283000000 | 12 | 34 | 256 qam | 19 |
5 | 291000000 | 11.9 | 34 | 256 qam | 20 |
6 | 299000000 | 12.9 | 33 | 256 qam | 21 |
7 | 307000000 | 13.5 | 34 | 256 qam | 22 |
8 | 315000000 | 13.9 | 34 | 256 qam | 23 |
9 | 323000000 | 13.6 | 34 | 256 qam | 24 |
10 | 339000000 | 13.9 | 33 | 256 qam | 26 |
11 | 347000000 | 14.3 | 33 | 256 qam | 27 |
12 | 355000000 | 13.9 | 33 | 256 qam | 28 |
13 | 363000000 | 13.4 | 33 | 256 qam | 29 |
14 | 371000000 | 13.5 | 33 | 256 qam | 30 |
15 | 379000000 | 13.4 | 33 | 256 qam | 31 |
16 | 387000000 | 13 | 33 | 256 qam | 32 |
17 | 395000000 | 12.1 | 32 | 256 qam | 33 |
18 | 403000000 | 12 | 32 | 256 qam | 34 |
19 | 411000000 | 11.4 | 32 | 256 qam | 35 |
20 | 419000000 | 11.5 | 32 | 256 qam | 36 |
21 | 427000000 | 12 | 32 | 256 qam | 37 |
22 | 435000000 | 12 | 32 | 256 qam | 38 |
23 | 443000000 | 11.9 | 31 | 256 qam | 39 |
24 | 451000000 | 12.3 | 31 | 256 qam | 40 |
1 | Locked | 34.3 | 4551621 | 0 |
2 | Locked | 34.3 | 2969395 | 0 |
3 | Locked | 34.4 | 2866529 | 0 |
4 | Locked | 34.3 | 3013360 | 0 |
5 | Locked | 34.4 | 3087595 | 0 |
6 | Locked | 33.9 | 3208727 | 0 |
7 | Locked | 34.3 | 3205444 | 0 |
8 | Locked | 34.3 | 3288567 | 0 |
9 | Locked | 34.4 | 3576691 | 0 |
10 | Locked | 33.9 | 4264978 | 0 |
11 | Locked | 33.9 | 4436057 | 0 |
12 | Locked | 33.9 | 4664078 | 0 |
13 | Locked | 33.4 | 5013322 | 1 |
14 | Locked | 33.3 | 5570055 | 4 |
15 | Locked | 33 | 6121794 | 34 |
16 | Locked | 33 | 6591923 | 170 |
17 | Locked | 32.6 | 6862842 | 691 |
18 | Locked | 32.5 | 7084477 | 2341 |
19 | Locked | 32.2 | 7255541 | 7678 |
20 | Locked | 32.2 | 7325373 | 14635 |
21 | Locked | 32.2 | 7357193 | 20887 |
22 | Locked | 32.2 | 7388826 | 33320 |
23 | Locked | 31.9 | 7408446 | 75260 |
24 | Locked | 31.9 | 7411939 | 74916 |
on 10-01-2021 20:08
1 | 46199949 | 43.8 | 5120 | 64 qam | 11 |
2 | 25799991 | 40.3 | 5120 | 64 qam | 14 |
3 | 32600007 | 41.8 | 5120 | 64 qam | 13 |
4 | 39400000 | 42.3 | 5120 | 64 qam | 12 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 15-01-2021 20:25
The technician came and checked yesterday. But he said it is the fault of the network where I am living and he couldn't do anything to fix it. So can I quit Virgin Media without any penalty? Because I have just joined a 18-month contract last month. They cannot provide the basic connecting service to me, is it possible cancel the contract without any surcharge?
on 15-01-2021 20:27
15/01/2021 20:19:14 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:18:11 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:17:2 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:16:59 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:14:31 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:11:46 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:11:27 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 20:08:24 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:57:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:57:44 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:57:24 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:54:40 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:47:59 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:46:23 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:35:13 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:28:28 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:19:53 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:19:8 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:18:34 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/01/2021 19:15:43 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 18-01-2021 21:11
18/01/2021 20:47:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 20:44:15 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 20:03:33 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 19:57:21 | Error | Service Add rejected - Required parameter not present;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 19:44:30 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 19:36:43 | Error | Service Delete Response rejected - Invalid Transaction;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 19:06:40 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 19:02:30 | Error | Service Change Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:57:44 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:55:13 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:49:50 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:48:21 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:35:4 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:33:26 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:29:56 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:29:27 | Error | DCC rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:20:36 | Error | Service Add Ack rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:06:3 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:03:20 | Error | DCC-ACK rejected authentication failure;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/01/2021 18:00:28 | Error | Service Add Response rejected - Invalid transaction ID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
