p_singh
Flashing Wifi-Light.
Hi, I have a flashing green wifi light at all times, ever since set-up.
Not sure if its an issue with the new Hub 3.0, or just a firmware update.
Broadband is working fine, I've had no problems.
Any answers?
  • 13.76K
  • 1.45K
  • 2.91K
Re: Flashing Wifi-Light.
If you are not using WPS, go into the hub settings & disable it. That will stop the hub from constantly scanning for connections.
Re boot & the WiFi light should go out after the self-test is complete.
Cable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
p_singh
Thanks again mate, after changing the settings and re-starting the hub it has gone away.
But for how long, guess I'll have to wait and see.
I'll let you know.
