Connection help
Hi, i need advice on what to buy to fix my problem. My wifi box is downstairs, i have cctv unit upstairs, it needs ethernet cable to connect but i dont want to drag a wire through the house. What can i buy that sits in the bedroom which picks up the wifi signal and i can just pop ethernet simply into cctv. Thank you
  • 651
  • 120
  • 204
Re: Connection help
Hi, you can get something called a powerline adaptor.  One plugs into a wallsocket by your Hub and connects to it via ethernet.  The other plug will plug in to a wall socket by your CCTV and you can plug an ethernet into this unit and into your cctv
Rich
Send Me a PM!
Here to help! I'm a Field Technician helping out from home. Find out more
REFER A FRIEND AND SHARE £100 BETWEEN YOU
****************** ASK ME HOW ******************
Re: Connection help
Hi thanks Rich i will have a look into one of these 😊
