Brunomiguel
Ac adapter replacement
Hi recently my hub 3.0 stopped working, and after checking what was wrong I found out that it’s the ac cable that’s not working, will virgin replace it or do I have to buy a new one??
  • 19.09K
  • 1.67K
  • 4.18K
Re: Ac adapter replacement
virginmedia can send a replacement free of charge, since all equipment is rented
If someone's helped you out say thanks by clicking on the thumbs up on kudos. If someone's solved your problem, why not mark their message as an Accepted Solution, but only do this once issue has been resolved.
