on 19-01-2023 17:06
Why when I spend a considerable amount of money each month for a 350MB Broadband connection do I have to endure the misery that is the Superhub 3???? I have spent good money out of my own pocket to add a TP-Link Deco Mesh system across the house with the SH3 just running in Modem mode.
It (SH3) is a poor device and will often freeze on the web login page meaning a power cycle is the only option.
The other night I had to do this three times before I could reset it.
It really is NOT fit for purpose and despite contacting VM about it they are not interested in replacing it despite my almost 19 years as a customer.
FED UP.
19-01-2023 17:12 - edited 19-01-2023 17:14
So all is well then when you have the Deco's running - but you are just making a point 🙂
If so, the shortcomings of VM hubs compared to the professional third party equipment is oft discussed on here.
If not did you set up the Deco's in the sequence that has been posted on here many times? If so - lets see the connection data - do this....
__________________________________________
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return.
If you have a Hub4 or 5 then login on the first page up. If you have an SH2 or Hub3 - dont log in just click on the “router status” icon/text at bottom-middle (Hub3) or top/right (SH’s) of the Login page.
Then Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
________________________________-
on 19-01-2023 17:52
Generally all is well with the Decos. Sometimes the broadband speed will crawl and when trying to reboot the hub the web logon is ina cessible.
Rebooting the SH3, lo and behold the speed increases again.
Such a poor device.
19-01-2023 18:06 - edited 19-01-2023 18:13
@dirtyharry73 wrote:Generally all is well with the Decos. Sometimes the broadband speed will crawl and when trying to reboot the hub the web logon is ina cessible.
Such a poor device.
Not too much different with other providers in all likelihood. I am using a BT Smart Hub 2 with their FTTP and their hub is nothing to write home about. In some ways the VM Hubs are actually a superior device!
If you are in modem mode, and using your own networking kit, you should have minimal issues. Follow the advice of jbrennand and post up some stat's from the VM hub to see if you have a problem with your VM connection.
on 22-01-2023 08:17
Hi there @dirtyharry73
Thank you for your post and welcome back to the forums.
I'm so sorry to hear you are facing issues with your connection, and thank you to our community team for their advise.
Are you able to post the Hub stats as requested?
on 22-01-2023 09:00
The Hub 3 does not always work perfectly with every web browser.
If you find the login is failing, you might try a switch to Chrome / Edge / Firefox etc to see if that helps.
on 29-01-2023 15:48
on 29-01-2023 15:49
on 29-01-2023 15:57
on 29-01-2023 16:13
