on 29-03-2023 02:07
Had VM in for a week and my download speed should be 500mbs.
On 1st few days no bother, however now it’s sitting at no more than 145mbs, when rebooting it speeds up but then reverts to slower speed.
also as a mobile O2 customer should I not be upgraded at no cost to 1gig being tge next fastest speed? I don’t know what to look for with this new Volt thing!!
on 29-03-2023 07:07
Samknows Realspeed
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
The speed at the Hub should reflect your subscription.
For a WiFi device the speed reflects its capabilities.
on 31-03-2023 11:12
Hi @Makembasher
Thanks for posting on our community forum and sorry to hear about the issue with your broadband.
Have you been able to run a speed test as advised above by Client62? How has your connection been over the past couple of days? Please do provide us with an update if possible.
on 01-04-2023 17:31
on 04-04-2023 11:00
Hello Makenbasher
Sorry to hear of the service issues and download speeds, we appreciate you taking the time to post via the forums.
From checking the account the speeds up till yesterday averaged 1149mbs download, there is currently an ongoing outage our technicians are working on. When you test the speeds, are they over a wired or wireless connection? The speed given is to the Hub but it may differ over a wireless network.
Rob
on 04-04-2023 13:54
Overnight last night for example I had no internet at all via the router. I had to revert to 4g which is not good. With Sky this never happened why now with Virgin?
if I do a speed test at random on my iPhone so wirelessly I sometimes get 340mbs but more often as low as 60-75mbs why such a range?
04-04-2023 16:20 - edited 04-04-2023 16:22
VM had a major outage last night and is now sorted hopefully.
As for the phone, it could be swapping between wifi bands, as the 5Ghz band is faster than the older 2.4Ghz band.
Split the SSID and add an _5 to the end of the 5Ghz band. That way you can choose which band to use.
on 04-04-2023 16:26
Err…..that may as well have been Martian! I didn’t understand a word of the advice you kindly offered!!!
04-04-2023 16:30 - edited 04-04-2023 16:31
The Hub uses 2 bands for wifi. 2.4Ghz, older, slower but more range. and the newer 5Ghz band, faster but less range. They both broadcast using the same name, or SSID.
If you logon to the Hub, you can "split" the SSID by renaming the 5Ghz band by adding an _5 to the end of the name and save the changes.
That way you will end up with 2 wifi names on your Hub, and you can choose between them depending on your needs.
HOWEVER - if you use Pods, or intend to get Pods from VM, you can't do this. The Wifi Max setup for Pods needs a single SSID.
