QAM 16, packet loss
Biscuit_Monster
I’ve noticed a couple of upstream channels flapping between 16 32 and 64 QAM along with an uptick in packet loss on my BQM graph.
I think my power levels are in spec, and nothing has changed inside the property, all connections look good.  Could this be an area issue (31) or noise in the cabinet (from a neighbour?).
There was a major outage a couple of months ago caused by a nearby lightning strike and upstream power was over 50 dBmV for a while after it was fixed, seems to be back to around 42 which is typical for my line.
Tried powering everything off for 5 minutes but levels are the same.
BQM (red lines after midnight are the shutdown period).
will post stats below.
11 REPLIES 11
Biscuit_Monster
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
482250000
0.2
38
256 qam
16
2
474250000
0.2
38
256 qam
15
3
490250000
0.2
38
256 qam
17
4
498250000
0
38
256 qam
18
5
506250000
-0.2
38
256 qam
19
6
514250000
-0.5
38
256 qam
20
7
522250000
-0.5
38
256 qam
21
8
530250000
-0.7
38
256 qam
22
9
538250000
-0.5
38
256 qam
23
10
546250000
-0.4
38
256 qam
24
11
554250000
-0.7
38
256 qam
25
12
562250000
-0.7
38
256 qam
26
13
570250000
-0.9
38
256 qam
27
14
578250000
-0.9
38
256 qam
28
15
586250000
-0.5
38
256 qam
29
16
594250000
-0.4
38
256 qam
30
17
602250000
-0.2
38
256 qam
31
18
610250000
-0.4
38
256 qam
32
19
618250000
-0.9
38
256 qam
33
20
626250000
-0.9
38
256 qam
34
21
634250000
-0.5
38
256 qam
35
22
658250000
-0.7
38
256 qam
36
23
666250000
-0.7
38
256 qam
37
24
674250000
-1
38
256 qam
38
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
7
0
2
Locked
38.9
5
0
3
Locked
38.6
5
0
4
Locked
38.6
6
0
5
Locked
38.9
7
0
6
Locked
38.9
8
0
7
Locked
38.6
6
0
8
Locked
38.6
8
0
9
Locked
38.6
7
0
10
Locked
38.6
17
0
11
Locked
38.6
7
0
12
Locked
38.9
6
0
13
Locked
38.6
9
0
14
Locked
38.9
8
0
15
Locked
38.9
10
0
16
Locked
38.9
5
0
17
Locked
38.6
10
0
18
Locked
38.6
8
0
19
Locked
38.9
11
0
20
Locked
38.9
5
0
21
Locked
38.9
10
0
22
Locked
38.9
17
0
23
Locked
38.9
14
0
24
Locked
38.6
21
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
43100000
43
5120
64 qam
6
2
36600000
42.5
5120
64 qam
7
3
30100000
43.5
5120
16 qam
8
4
23600274
42.5
5120
16 qam
11
5
49600258
43.5
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
0
0
All your US channels should be 64QAM, so I suspect noise igress somewhere.  Check all the connections are tight.  Also post your Network Log please for comment.
Agree. Connections all tight, cables haven’t been touched and don’t run near anything that could pick up noise (power etc). Pretty sure it’s an issue in the cabinet.
01/01/1970 00:01:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2023 11:18:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2023 09:21:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2023 00:04:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2023 00:04:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/11/2023 00:03:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/11/2023 21:07:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2023 12:32:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2023 09:07:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2023 15:48:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/11/2023 21:07:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2023 12:19:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2023 09:07:47ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2023 18:23:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2023 10:49:19ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2023 03:09:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2023 03:01:18criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2023 02:58:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2023 02:58:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2023 02:58:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Nothing jumping out in the logs AFAICS.  Looks like you need a VM engineer to check the circuit out.  If you have one of the older metal box isolators/splitters, it could also be failing/corroding?
Thanks for looking, could be some corrosion on whatever is in the box on the outside wall I suppose, I’ve never actually looked inside!
Inside the house is a white HDU-200 amplifier/splitter, only about 3 years old. PSU died on the last one after 10 years or so.
Hey @Biscuit_Monster,
Thanks for reaching out to us, looking into the diagnostics I can run via our system, I do not see any issues presently affecting you, has the issue since improved over the weekend?
Joe
Your diagnostics do not include hub auto downgrading Modulation
