Brown box damaged
Vindiesel5000
Hi. My VM wifi has been intermittent and also slow for around two months now.
move reported on then phone (6 weeks ago) to be told works were being done in the area.
6 weeks later wifi is still dropping out and when it does work, is slow.
The brown box on the outside of the house is also damaged and won’t stay shut so it’s exposed to the elements.
Can someone please help?
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Re the omnibox cover - post up a photo here for a VM person to assess thr damage and arrange a "fix".
Re. the connection issues...
Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
Also,
check for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Post back here what's reported on those two.
12 REPLIES 12
Also,
Vindiesel5000
Hi, John, thanks for your reply.
Ive currently glued their box together so no point taking a photo - it’s VERY old though ad suffered damage with the wind & rain etc over time.
Service checker website showed no issues. Tel service shows there are no issues in the postcode either.
It’s a Hub 3. The light on the front is yellow currently.
I don’t have any devices that have an ethernet port so cant comment there
You can get adapters with ethernet ports that will connect any device to the Hub via any port your device has - I have them with USB3, USBc, T'bolt, firewire and lightning - so I can connect any of my many Apple devices.  Amazon has a good selection
Lets see your connection details - do this...
_____________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Hi @Vindiesel5000
I am sorry to hear of any WiFi issues and the Omnibox issue.
I'll send you a PM now to book in the Omnibox tech to sort that out.
Please also do as jbrennand has suggested, as no issues are showing here.
Best wishes.
John_GS
Hello, my brown box has been completely blo n off & inside panel with wires etc is also just handling on & exposed. Can you assist!?
Many thanks,
David
Hi @Cunny316 👋.
Thanks for reaching out to us. We can certainly assist you with the missing cover that has gone with the wind, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
Hello
My brown box cover is also missing in action. Any chance I could get a replacement?
thanks.
Hi Sabrina,
I've got a damaged external brown box too a d no way to reattach it to the wall. Could I get a replacement sent out to me that I can attach to the wall as I have exposed wires to the elements.
