on 16-05-2023 13:13
About once a week I have to reboot my router to get the speed I pay for.
Rebooting fixes it for a around a week then it drops back to 10% again.
How can VIrginmedia fix this problem?
PS The answer isn't to keep rebooting. the router.
on 17-05-2023 10:24
Perhaps you have a faulty network cable that is de-rating from 1000Mb/s to 100 Mb/s.
This would cause a large drop in speed & might recover for a short period after kit is restarted.
on 19-05-2023 10:45
Hi Bezzaman,
Thanks for taking the time to post about your issues in the Community. ⭐
We're sorry to hear you're having an issue with your speeds dropping every so often.
Checking things this end, I can see that the signal and power levels are all optimal, there are no faults in your area either. All is as it should be.
Do you find this happening on all devices or are you noticing it on one device?
Has the advice from Clent62 helped at all?
Pop back and let us know.
on 19-05-2023 15:05
No network cable involved as it is using wifi.
Happening on all devices.
This is a list of errors from the router network log which goes back to 11th May:
18/05/2023 19:03:8 - Warning! - RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2023 10:57:34 - critical - No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/05/2023 14:27:12 - critical - No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/05/2023 22:44:2 - critical - No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2023 17:48:45 - critical - No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**CM-QOS=1.1;CM-VER=3.0;
12/05/2023 10:23:11 - Warning! - RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/05/2023 18:35:18 - critical - No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
There are various DCHP errors which I have excluded as I assume they are not relevant to the issue.
on 21-05-2023 15:54
Hi @Bezzaman,
Thanks for coming back to us about this ongoing issue! I've checked our systems again and I cannot see any issues.
Can you tell us what speeds you're receiving on a wired connection so that we can look into this further?
Have you taken a look at our Speed Up page to see if this can help?
Is it just your speed that drops, or do you experience connection drops as well?
Please let us know so that we can help further.
Thank you.
on 22-05-2023 21:30
Are the above messages "RCS Partial Service" and "No Ranging Response" an issue?
When the problem recurs I will check the wired connection speed and let you know.
I am using imUp to monitor the connection.
on 22-05-2023 21:44
1 | 53700004 | 41 | 5120 | 64 qam | 10 |
2 | 39400000 | 41 | 5120 | 64 qam | 12 |
3 | 46199991 | 41 | 5120 | 64 qam | 11 |
4 | 60299996 | 41 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 22-05-2023 21:45
Above is Upstream data from the Hub
on 25-05-2023 11:30
Hi Bezzaman, thank you for all the posts and updates about this matter.
Regarding your service received, upon our latest checks there don't seem to be any issues currently.
Neither does our local network, things are pretty clear on this end. 🙂
I've also run some background tests for the wireless network and it all looks good at the minute, devices look happy with signal and speeds.
Are you able to update us on whether you've had further connection or speed issues since Monday?
Let us know where you are with this and we're here to assist further where needed.
