Constant gig 1 issues, slow downloads, constant drop outs.
Hm121
Been a gig 1 user for a while now and in all honesty, it's been an awful experience, paying for something which virgin isn't delivering. At this moment in time using a wired connection I can get speeds from 60-70 mb up to 700-800 tops, constant dropouts and the only thing that resolved this is to keep resetting the hub 4.
When we first took out the broadband it was advertised on virgin's site that gig 1 users would get the hub 5, granted it doesn't seem like virgin no longer advertises that anymore but regardless I am 100% certain it was stated when you took out a contract and I can find this of required. We were also promised a hub 5 by several different people and have never received one, we spoke with virgin roughly 2 weeks ago and they promised to send a hub out and instead we were sent a power supply....
I spoke with virgin again last week regarding the power supply that was sent out and the issues with keep having to reset the current hub which suggests that it's a hub issue and I was told that I wouldn't be getting a hub5 regardless because the hub 4 supports 1 gig and therefore it's sufficient, well by that logic the hub 3 supports 1 gig so why not give everyone a hub 3 then? The "technical advisor" also stated that she had more experience then me and knew what she was talking about, which I highly doubt, I am an engineer by trade and I don't appreciate sarcastic comments from someone with zero hands on experience. The fact that the current hub needs resetting to regain the speed would indicate that the hub is the issue.
So, at this moment in time all I can see is that I am paying for a service which I have never got since day 1 and that virgin have lied at every single opportunity.
11 REPLIES 11
Hub 3 doesn’t support 1Gb Tier.
Test this site with a wired connection and post the results. Run the FULL test.
www.samknows.com/realspeed
Hi Adduxi,
Thanks for the reply, please see the screenshot, this is a desktop pc in the room next to the hub using a wired connection
Okay, so the link to your Hub is slightly lower than expected, but still pretty good.  As for the Desktop, that's the bottleneck.  Try a "known good" Cat 6 cable and if using Windows, retest in "Safe Mode with Networking Support" or alternatively boot the PC from a Linux ISO and test.
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Post the power levels, Pre and PostRS errors and network log from the Hub. Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
Hi Adduxi,
All the cables are a minimum of cat 6 already, if I were to go and reset the hub then I would most likely get a higher download speed for a short period of time but it never sticks and its just rinse and repeat.
That's why we need to see the power levels etc.  Just copy and paste the information here for comment.  Also the BQM will show any historical problems with your circuit.
Thanks.
Hm121
Please see below:
3.0 Downstream channels
253310000003.239QAM25625
11390000007.440.4QAM2561
21470000006.840.4QAM2562
31550000006.740.4QAM2563
41630000005.840.4QAM2564
51710000005.440.4QAM2565
61790000004.940.4QAM2566
71870000005.340.4QAM2567
81950000005.340.4QAM2568
92030000004.840.4QAM2569
102110000004.640.4QAM25610
112190000004.340.4QAM25611
122270000004.640.4QAM25612
132350000005.140.4QAM25613
14243000000540.4QAM25614
152510000005.540.4QAM25615
162590000004.640.4QAM25616
172670000004.839QAM25617
182750000004.640.9QAM25618
192830000004.539QAM25619
202910000005.540.4QAM25620
212990000004.638.6QAM25621
223070000004.640.4QAM25622
233150000003.739QAM25623
24323000000339QAM25624
263390000002.839QAM25626
273470000003.540.4QAM25627
283550000003.440.4QAM25628
293630000003.939QAM25629
303710000003.339QAM25630
313790000003.539QAM25631
25Locked38.98326100
1Locked40.36628700
2Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.36628700
7Locked40.36628700
8Locked40.36628700
9Locked40.36628700
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.36628700
17Locked38.98326100
18Locked40.94620900
19Locked38.98326100
20Locked40.36628700
21Locked38.60537700
22Locked40.36628700
23Locked38.98326100
24Locked38.98326100
26Locked38.98326100
27Locked40.36628700
28Locked40.36628700
29Locked38.98326100
30Locked38.98326100
31Locked38.98326100
3.1 Downstream channels
159964K1840QAM4096759
159Locked412.1371296324860
Hm121
3.0 Upstream channels
123600000395120 KSym/secQAM645
23010000040.55120 KSym/secQAM644
33660000040.55120 KSym/secQAM643
44310000040.55120 KSym/secQAM642
549600000415120 KSym/secQAM641
3ATDMA0000
4ATDMA0000
5ATDMA0000
3.1 Upstream channels
610.035.02KQAM32
6OFDMA20053.900
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
kfoA,.iyewrkldJKDHSUBsgvc
SFID
178
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
177
Max Traffic Rate
110000274
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Hm121
Tue 26/12/2023
15:31:15
6US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/12/2023
14:22:11
6CM-STATUS message sent. Event Type Code: 5; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/12/2023
14:21:50
5Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 26/12/2023
14:21:32
Tue 26/12/2023
14:21:18
Tue 26/12/2023
14:07:37
Tue 26/12/2023
11:34:17
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 25/12/2023
23:43:50
Mon 25/12/2023
12:34:04
Mon 25/12/2023
07:24:13
6CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 25/12/2023
03:27:49
Sun 24/12/2023
21:54:11
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 24/12/2023
21:47:57
6DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 24/12/2023
21:47:56
4DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 23/12/2023
22:24:29
Sat 23/12/2023
15:30:25
Sat 23/12/2023
00:58:32
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
22:35:35
Fri 22/12/2023
20:46:53
Fri 22/12/2023
19:45:58
6CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
19:15:41
6US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
19:15:41
5DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
19:15:23
5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
17:47:25
Fri 22/12/2023
17:47:25
Fri 22/12/2023
17:47:06
Fri 22/12/2023
17:43:37
6SW download Successful - Via Config file
Fri 22/12/2023
17:42:15
Fri 22/12/2023
17:42:15
Fri 22/12/2023
17:42:14
6SW Download INIT - Via Config file ;fg87dsfd;kfoA,.iyewrkldJ
Fri 22/12/2023
17:41:57
6CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 22/12/2023
17:41:57
Hm121
I will upload a BGQ graph tomorrow once its had 24 hours to log stuff.
