on 15-06-2023 16:07
I currently am paying £67.25 for M350 Fibre Broadband. It used to be £60 and I don't know why virginmedia hiked the price. I've found out that I can get 1gbps from virginmedia for £62, but when I try to upgrade by signing in to virginmedia it says I have to pay an extra £13.30 on top of the £67.25 as a monthly fee to get the 1gbps broadband.
Also, my router has been acting up for days where I'm losing connection randomly during the day.
Would be happy if somebody can reach out and help address these to concerns of mine.
16-06-2023 15:23 - edited 16-06-2023 15:24
Has your package moved to the 30-day rolling contract that happens automatically when your 12/18/24 month initial contract expires?
If so you are in a good place to get a new deal - report back here for pointers.
Re the Hub playing up - are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
18-06-2023 14:11 - edited 18-06-2023 14:11
Thank you for responding!
The issue is there using WiFi and ethernet.
on 19-06-2023 10:44
£67.25 for 350?
Holy that's expensive.
on 22-06-2023 16:28
Hi hortonj88,
Do you know whether BT or other ISPs have newer WiFi technology such as WiFi 6? If they do, do you think that is a better option?
Thanks, by the way for reaching out!
on 22-06-2023 19:22
One can easily add Wi-Fi 6 access points to any ISP's Hub / Router.
on 23-06-2023 14:41
How can somebody go about doing that?
23-06-2023 15:20 - edited 23-06-2023 15:22
Just buy wifi 6 access points and connect them up. It's easy to do and you don't need to be very technical to do this.
I have 3 access points as my router is a non wifi unit, as that's my preference.
on 23-06-2023 18:58
Hi Lawikekurd2010,
Thank you for your post. I am sorry to hear about the issue you're having with your broadband service.
Is the speed issues affecting both a Wired & Wireless connection?
Can you confirm the hub you currently have?
^Martin
on 23-06-2023 19:16
Hi Martin,
Yes, both wired and wireless is affected. My connection drops out several times a day.
I have a Hub 3 that was provided by Virginmedia several years ago.
