on 07-10-2023 08:02
Wh
The white plug that power the white box on the wall is playing up. If I take is out when I am cleaning and then put it back in again It now started making a clicking noise and the green light flashes. So I have to plug it in the other plug socket and it then works
How do I get new one. As I work from home and need the internet.
on 07-10-2023 08:20
From past topics, I believe you need a tech visit as the plug-top power supply is not a part that can be sent out. I think the flashing indicates a pending problem.
Personally, I would not be plugging/unplugging that equipment as it is meant to be always-on.
One of the VM forum team will reply here within a few days.
on 07-10-2023 09:16
Are you sure it's not the wall socket that's at fault? Have you tried other devices in that socket?
on 07-10-2023 10:22
I assume the socket is okay, as it's used when cleaning. Sounds like that single socket needs to be replaced by a double. As @goslow said, these power units are designed to be on all the time. It's not good to be powering your broadband circuit up and down constantly.
on 07-10-2023 10:30
The OP said the PSU is OK in another socket.
on 07-10-2023 10:31
@jpeg1 wrote:The OP said the PSU is OK in another socket.
Oops ! Missed that one ..... 🙂
on 07-10-2023 12:31
Similar clicking/ticking description mentioned here for a similar-looking setup.
@Dazyellow3 Is it the plug-top power supply that is making the ticking sound or the white plastic box on the wall?
Is you connection dropping when the light is flashing and you hear the ticking sound?
Does the light flash/ticking sound begin only when you unplug it for cleaning or is it a permanent feature?
Does the flashing light /ticking sound always happen with the power supply always plugged in one wall socket and never in the other power socket?
More info needed but I would guess that the amplifier and/or power supply is possibly on its way out and the act of switching between sockets restarts it and temporarily clears the issue.
on 07-10-2023 17:33
Is you connection dropping when the light is flashing and you hear the ticking sound? No is the answer. My broadband and TV are fine
The light flash/ticking sound begin only when I plug in the white plug and the green light on the white plug and the white box on the wall start to flash about 5 times before stopping. Then the green light stays on.
Like what @goslow mentioned above the amplifier and/or power supply is possibly on its way out as I had the white plug and white box on the wall for about 5 years. I had it installed when I used to have 2 V6 boxes. I now only got the one 360 box. Hope this makes sense.
on 07-10-2023 17:39
How do I get a technician out to replace either the white plug or the white box on the wall? As I mentioned in my first post. I work from home and need internet.
on 07-10-2023 17:49
You can call Customer Service and report a fault. But if the technician can't find a fault they will charge you £25.
