on 31-07-2023 06:35
Hi, I have around 280mbps from my Hub 3 but from the tp-link upstairs but I’m only getting 30mbps, any ideas
thanks
on 31-07-2023 06:41
What model is the TP-Link?
on 09-08-2023 12:51
TL-WR841N It says 300Mbs on it
on 09-08-2023 13:32
Hi @Wayne68
Is the hub in Modem Mode or is this a booster you've purchased?
Could you also download the Connect App for me and then run some wireless scans in your property? This will make sure you're receiving good speeds and help you if not. Let me know 🙂
Best wishes.
on 09-08-2023 15:14
Not sure what you mean by in modem mode, I have a virgin hub3 in living room and upstairs I have a Tp-Link Wi-Fi router connected to my virgin hub with a Ethernet cable, I’ve done a test with the app and it’s showing download 274Mbps from hub it only 17Mbps from the tp-link
09-08-2023 15:29 - edited 09-08-2023 16:00
TL-WR841N is an 802.11n/b/g 2.4 GHz WI-Fi Router / Access Point. Hopefully configured in Access Point mode.
300Mb/s is marketing speak as on 2.4Ghz, 802.11n connects at 150Mb/s max in each direction and Wi-Fi is half duplex. Many mobile phone connect at 2.4Ghz but often at a max link rate of 72Mb/s so expect real world speed tests to be up to 50Mb/s.
Still 17 does seam low. Is the TL-WR841N using Access Point mode ?
If it was in Router Mode that would create double NAT situation and an extra firewall which are not needed.
on 09-08-2023 15:53
And it only has 10/100 Ethernet ports….
09-08-2023 16:57 - edited 09-08-2023 16:58
As adduxi says - that is a very old model limits to sub-100 speeds - time to upgrade
look at this as a starter router and access point...
https://www.amazon.co.uk/Archer-C6-Wireless-Supports-Parental/dp/B07L5YRYF4/
on 09-08-2023 17:47
How would I find out what mode it’s in?
on 09-08-2023 18:11
Check the manual for your version of TL-WR841N ; https://www.tp-link.com/uk/support/download/tl-wr841n/
Connect to it using a web browser and review the configuration.
