Channel Islands not in roaming
TM51
I want to upgrade to use data here on holiday but the text system to do this is down. Is there another way I can get back to using my data?
1 ACCEPTED SOLUTION
Accepted Solutions
Sabrina_B
Hi @TM51.
Thanks for reaching out to us. We would advise you to contact the sales department for any changes to your package. You can do this via 📞 +44 7953 967 967.
Hope this helps.
Sabrina
4 REPLIES 4
Sabrina_B
Hi @TM51.
Hope this helps.
Sabrina
enlli
The Channel Islands are hit and miss when roaming. They are not included in your EU roam like home allowance and data is chargable. That is, if you can get your phone to roam there in the first place.
Do a forum search for Chanel Isles / Jersey / Guernsey
Thanks but the number is unobtainable.
Hi TM51,
Sorry to hear that the number isn't working for you.
Alternatively, you can message us via Whatsapp on +447305 327 112
Let us know if you need anything else
Beth
