Hub 5 drop out
LeighDaz
Having issues, with the hub 5. We have the 1gb contract. Every day the download speed drops to about 1meg. Run diagnostics and it says the hub needs a reset. This is now happening once or twice daily. Help please
1 ACCEPTED SOLUTION
Accepted Solutions
Upstream power too high and downstream power out of spec. Probably you are a long way from the street cabinet. You need moving to another tap on the street cabinet unless there is an area fault. You need a technician’s visit to rectify.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
VM will not dispatch any technicians while an area fault exists.
If no area faults found:
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
10 REPLIES 10
Sounds like a circuit issue. Post the power levels and network log please.
From what I can see the downstream power levels are way too low. Cannot read photos of stats very easily, please follow this and post a new set of stats:
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
  • Click on the “> Check router status” button
  • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
  • Click on the “Upstream” tab, copy the text and paste into your reply
  • Click on the “Networking” tab, copy the text and paste into your reply.
    • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
3.0 Downstream channels
1331000000-7.839QAM 25625
2139000000-2.539QAM 2561
3147000000-2.939QAM 2562
4155000000-3.439QAM 2563
5163000000-439QAM 2564
6171000000-4.439QAM 2565
7179000000-4.839QAM 2566
8187000000-4.939QAM 2567
9195000000-539QAM 2568
10203000000-5.239QAM 2569
11211000000-5.339QAM 25610
12219000000-5.539QAM 25611
13227000000-5.939QAM 25612
14235000000-6.439QAM 25613
15243000000-6.838QAM 25614
16251000000-7.238QAM 25615
17259000000-7.738QAM 25616
18267000000-7.838QAM 25617
19275000000-7.539QAM 25618
20283000000-739QAM 25619
21291000000-7.139QAM 25620
22299000000-739QAM 25621
23307000000-7.139QAM 25622
24315000000-7.439QAM 25623
25323000000-7.738QAM 25624
26339000000-7.938QAM 25626
27347000000-8.138QAM 25627
28355000000-8.338QAM 25628
29363000000-8.138QAM 25629
30371000000-8.138QAM 25630
31379000000-8.238QAM 256
31
3.0 Upstream channels
04960000051.85120QAM 641
143100000515120QAM 642
236600000515120QAM 643
33010000050.55120QAM 644
42360000049.85120QAM 645
31-12-2023 19:26:41warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 19:26:41noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 19:16:36noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 19:16:36warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 19:06:31noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 19:06:31warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:56:25warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:56:25noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:46:20noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:46:20warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:36:17noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:36:17warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:26:12noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 18:26:12warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:56:34noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:59warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:59noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:55noticeREGISTRATION COMPLETE - Waiting for Operational status
31-12-2023 17:55:49warningDynamic Range Window violation
31-12-2023 17:55:49warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:49warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:49warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:43noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:35warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 17:55:33noticeHonoring MDD; IP provisioning mode = IPv4
31-12-2023 17:55:18criticalCable Modem Reboot because of - HW or Power-On Reset
31-12-2023 17:55:18criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 11:28:03criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-12-2023 11:28:02criticalUnicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Bad hub wifi
Hi there @LeighDaz Thanks for reaching out to us and a warm welcome to the Virgin Media Community forums. 👋🏼
I'm sorry to hear about the issues with the connection you have recently experienced.
I've had a look and I can see there are quite a high substantial amount of drops on the line.
This will need further investigating and I will assist you on this and send a private message.
Kind regards,
Ilyas.
Ilyas_Y
