on 27-02-2024 17:07
I'm a existing customer and having a new pressed Concrete drive in the summer. The current cabling runs under some chippings from a wall which is also being removed. I basically need a conduit for the cable to run from street to my wall mounted box and this moved higher so it's not in the way. Having the cabling just under the concrete will cause issues later on if i go full fibre.
Ive tried ringing Virgin via the phone but just get moved from department to department. Can You assist with this query ?
on 01-03-2024 14:51
Hi @JamieS2 Thanks for reaching out to us on the Virgin Media Community forums. 👋🏼
I'm so sorry to hear you've been transferred round the departments for your query, this really is not the way we go with these queries.
I have raised this query to the head engineers in your area and and have saved / noted down this interaction so that when they provide an update or answer for your question - I will be able to advise regarding this.
I can't guarantee when the engineers will reply but they usually reply within a short time frame of 48 hours depending on their work and crew online.
Once they update us, we'll keep you in the loop. 🙂
Kind regards,
Ilyas.
on 01-03-2024 15:16
Thanks Ilyas await the reply with great anticipation ,, 👍
05-03-2024 14:42 - edited 05-03-2024 14:44
We'll be sure to let you know as soon as we have any update for you @JamieS2
on 26-03-2024 06:49
Any Update on this? looking at new drive May/June @Carley_S
26-03-2024 09:16 - edited 26-03-2024 09:17
I think you will find VM reluctant to spend so much on installing a deep conduit for you when you already have a working cable . You may need to get your builders to put in a conduit with a pull cord when they lay the concrete drive.
The wall box move should be possible as a standard £25 no fault visit.
a month ago
Hi JamieS2,
I've checked with Ilyas and I'm afraid he hasn't received a response to this yet, but we have chased them for a reply.
We'll keep you posted and we're sorry to keep you waiting.
3 weeks ago
Update - Hiya , since had a engineer(simon) out to move box on wall and remove unused cabling. However i still need a conduit for cable from street to house.. before i. Can have my drive way done in June
3 weeks ago
As said above, there's no reason for VM to spend all that money on a connection that's working perfectly. They aren't that generous. You'll need to get your builder to do it.
3 weeks ago
Hi there @JamieS2
Thank you for popping back to us and I would be more than happy to pop you a private message so we can grab some information and see what we can do.
