on 24-07-2023 10:14
After a lot of rain yesterday my internet went off. Did the usual switch off and on etc. and eventually left it overnight.
I didn’t get a chance to check outside until this morning but the cover to my brown box has come off and it’s full of rainwater.
Am I best to empty the water out, leave it to dry out and assume the internet will simply start working again? Or does this need attention from a technician?
on 24-07-2023 11:40
VM cables are fairly resilient, but the fibre connections behind the inside cover may have been affected? It might be worthwhile checking those.
on 24-07-2023 13:35
It's likely that the box falling off has damaged the fibre, so you should book an engineer.
24-07-2023 13:47 - edited 24-07-2023 13:51
The fibre to coax convertor, behind the plastic panel, may have shorted:
Does the electrical plug have a green LED (Fuse could have blown)?
on 24-07-2023 15:41
Update - left the cover off and dried in the sun for 3/4 hours. Internet back but only at a fraction of full speed. Tried to book an engineer but Virgins online checker is failing at the final stage, and tells me to “check back later”.
on 24-07-2023 20:02
If you wait here a couple of days a VM Mod will pick this up and arrange a technician.
on 25-07-2023 15:33
Hi Andyh11,
Thanks for raising your post and welcome to the community.
Sorry to see that the external box cover is faulty, so we can get this sorted I've dropped you a PM to discuss further.
The message will appear within the envelope icon.
