Virgin upgrade works has messed up power levels
madmanx
Hi had some work on my local network done today as it says it was doing upgrade work to improve the services,
But after being down for half the day when the hub came back online I saw the power levels are way out if sync now. The downstream before was between 0 and 3dbmv and the upstream dbmv was about 38 dmbv, now the downstream is +10 dbmv and the upstream is now around 34dbmv, do I need an engineer to fix it? I have a 6db forward path attenuater fitted at back of hub which i could change to a 10db forward path attenuator to bring down the downstream power levels but its the upstream I'm concerned about as its only 34dbmv?
Have I a problem now?
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
PasswordShow
Router status
11387500009.838256 qam1
21467500009.538256 qam2
31547500009.538256 qam3
41627500009.538256 qam4
51707500009.638256 qam5
61787500009.538256 qam6
71867500009.538256 qam7
81947500009.638256 qam8
92027500009.638256 qam9
102107500009.538256 qam10
112187500009.638256 qam11
122267500009.638256 qam12
132347500009.838256 qam13
142427500009.638256 qam14
152507500009.838256 qam15
162587500009.838256 qam16
172667500001038256 qam17
182747500009.838256 qam18
192827500009.838256 qam19
202907500009.838256 qam20
212987500001038256 qam21
223067500001038256 qam22
233147500001038256 qam23
2432275000010.138256 qam24
1Locked38.960
2Locked38.660
3Locked38.660
4Locked38.950
5Locked38.670
6Locked38.650
7Locked38.6180
8Locked38.9150
9Locked38.950
10Locked38.960
11Locked38.640
12Locked38.970
13Locked38.950
14Locked38.950
15Locked38.940
16Locked38.650
17Locked38.660
18Locked38.640
19Locked38.950
20Locked38.960
21Locked38.660
22Locked38.950
23Locked38.950
24Locked38.950
73 REPLIES 73
madmanx
Welcome back!
PasswordShow
Router status
14960000034.5512064 qam1
22360000034512016 qam5
33660000035.5512016 qam3
43010000034512064 qam4
54310000034.3512064 qam2
3ATDMA0000
4ATDMA0000
5ATDMA0000
jb66
What problem are you experiencing?
madmanx
Hi jb66 upstream is playing up,  the upstream modulation which was all at 64qam have dropped, are my power levels wrong now?
Welcome back!
PasswordShow
Router status
3ATDMA0000
4ATDMA0000
5ATDMA0000
madmanx
Welcome back!
PasswordShow
Router status
14960000034.8512064 qam1
22359956134512016 qam5
33660000034.3512032 qam3
43010000034.2512016 qam4
54310000034.3512032 qam2
3ATDMA0000
4ATDMA0000
5ATDMA0000
unisoft
Well-informed
If you have rebooted and checked all connections are tight (blah blah) then you'll need a tech visit as your QAM levels are wrong on 4 upstream channels. They should all be 64QAM on a normal connection. Whilst they can work at lower levels, it normally means less bandwidth. The other figures are fine though unless you start having around 29db on upstream.
Legend
You can try the 10dB attenuator to see if that improves ( lowers ) the downstream power figures. You can even try both attenuators ... but look carefully at the outcome, -7 to +7 dBmV is the preferred range.
The upstream, remember the direction, this power level is showing how strongly the VM Hub is transmitting to the street cabinet. The real concern here is the channels are not all holding at QAM 64, suggesting there is an SNR issue in the locality. As the power levels are not high, the issue may be affecting everyone local to you.
madmanx
Hi I put the 10db forward path attenuator on and took the 6db one off but straight away I noticed that videos were freezing/lagging so I put the 6db one back on again, but now power levels are going over 10dbmv again, what do I do now? Can virgin send me a 10db attenuator or should I request an engineer to adjust the power levels in the cabinet? Also upstream levels were all at 64qam but now are playing up again, so much for upgrading our service.
madmanx
Welcome back!
PasswordShow
Router status
1202750000938256 qam9
2210750000938256 qam10
32187500009.138256 qam11
42267500009.338256 qam12
52347500009.338256 qam13
62427500009.138256 qam14
72507500009.338256 qam15
82587500009.438256 qam16
92667500009.538256 qam17
102747500009.538256 qam18
112827500009.538256 qam19
122907500009.538256 qam20
132987500009.938256 qam21
143067500009.638256 qam22
153147500009.938256 qam23
163227500001038256 qam24
1733075000010.338256 qam25
1833875000010.438256 qam26
1934675000010.338256 qam27
2035475000010.138256 qam28
2136275000010.138256 qam29
2237075000010.338256 qam30
2337875000010.138256 qam31
243867500001038256 qam32
1Locked38.950
2Locked38.990
3Locked38.670
4Locked38.6130
5Locked38.990
6Locked38.680
7Locked38.9110
8Locked38.6110
9Locked38.9100
10Locked38.990
11Locked38.6100
12Locked38.9120
13Locked38.9140
14Locked38.670
15Locked38.670
16Locked38.9110
17Locked38.970
18Locked38.990
19Locked38.990
20Locked38.6110
21Locked38.990
22Locked38.960
23Locked38.690
24Locked38.9190
madmanx
Welcome back!
PasswordShow
Router status
14959992636.5512064 qam1
23660005436.3512064 qam3
33010000036512064 qam4
44310007336.5512064 qam2
52360000536512032 qam5
3ATDMA0000
4ATDMA0000
5ATDMA0030
