on 30-11-2023 19:50
Hi had some work on my local network done today as it says it was doing upgrade work to improve the services,
But after being down for half the day when the hub came back online I saw the power levels are way out if sync now. The downstream before was between 0 and 3dbmv and the upstream dbmv was about 38 dmbv, now the downstream is +10 dbmv and the upstream is now around 34dbmv, do I need an engineer to fix it? I have a 6db forward path attenuater fitted at back of hub which i could change to a 10db forward path attenuator to bring down the downstream power levels but its the upstream I'm concerned about as its only 34dbmv?
Have I a problem now?
Password | Show |
1 | 138750000 | 9.8 | 38 | 256 qam | 1 |
2 | 146750000 | 9.5 | 38 | 256 qam | 2 |
3 | 154750000 | 9.5 | 38 | 256 qam | 3 |
4 | 162750000 | 9.5 | 38 | 256 qam | 4 |
5 | 170750000 | 9.6 | 38 | 256 qam | 5 |
6 | 178750000 | 9.5 | 38 | 256 qam | 6 |
7 | 186750000 | 9.5 | 38 | 256 qam | 7 |
8 | 194750000 | 9.6 | 38 | 256 qam | 8 |
9 | 202750000 | 9.6 | 38 | 256 qam | 9 |
10 | 210750000 | 9.5 | 38 | 256 qam | 10 |
11 | 218750000 | 9.6 | 38 | 256 qam | 11 |
12 | 226750000 | 9.6 | 38 | 256 qam | 12 |
13 | 234750000 | 9.8 | 38 | 256 qam | 13 |
14 | 242750000 | 9.6 | 38 | 256 qam | 14 |
15 | 250750000 | 9.8 | 38 | 256 qam | 15 |
16 | 258750000 | 9.8 | 38 | 256 qam | 16 |
17 | 266750000 | 10 | 38 | 256 qam | 17 |
18 | 274750000 | 9.8 | 38 | 256 qam | 18 |
19 | 282750000 | 9.8 | 38 | 256 qam | 19 |
20 | 290750000 | 9.8 | 38 | 256 qam | 20 |
21 | 298750000 | 10 | 38 | 256 qam | 21 |
22 | 306750000 | 10 | 38 | 256 qam | 22 |
23 | 314750000 | 10 | 38 | 256 qam | 23 |
24 | 322750000 | 10.1 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 6 | 0 |
2 | Locked | 38.6 | 6 | 0 |
3 | Locked | 38.6 | 6 | 0 |
4 | Locked | 38.9 | 5 | 0 |
5 | Locked | 38.6 | 7 | 0 |
6 | Locked | 38.6 | 5 | 0 |
7 | Locked | 38.6 | 18 | 0 |
8 | Locked | 38.9 | 15 | 0 |
9 | Locked | 38.9 | 5 | 0 |
10 | Locked | 38.9 | 6 | 0 |
11 | Locked | 38.6 | 4 | 0 |
12 | Locked | 38.9 | 7 | 0 |
13 | Locked | 38.9 | 5 | 0 |
14 | Locked | 38.9 | 5 | 0 |
15 | Locked | 38.9 | 4 | 0 |
16 | Locked | 38.6 | 5 | 0 |
17 | Locked | 38.6 | 6 | 0 |
18 | Locked | 38.6 | 4 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 38.9 | 6 | 0 |
21 | Locked | 38.6 | 6 | 0 |
22 | Locked | 38.9 | 5 | 0 |
23 | Locked | 38.9 | 5 | 0 |
24 | Locked | 38.9 | 5 | 0 |
on 19-04-2024 15:28
Hey madmanx, thank you for reaching out and I am sorry to hear about this.
I can see you've spoken to the team about this, did they manage to help at all?
Matt - Forum Team
New around here?
on 28-04-2024 16:52
Hi seph I managed to lift cover up it's full of mud will post photo
on 28-04-2024 16:58
Is that wet mud? The photo has to be approved by someone and that might take a while. Wet mud can cause electrolytic effects - depends on how well insulated the cables and connectors are. Water is much worse than mud, though. This is stuff to tell the tech when he/she arrives.
on 28-04-2024 17:34
Hi seph yeah the mud is damp not soaking wet though, hopefully moderator will approve photo soon so u can see it, it's been raining for couple of days and as expected the upstream qam on the lowest frequency has dropped to 16qam.
on 28-04-2024 17:35
Password | Show |
1 | 23600033 | 34.2 | 5120 | 16 qam | 5 |
2 | 36600167 | 34.5 | 5120 | 64 qam | 3 |
3 | 43100000 | 34.8 | 5120 | 64 qam | 2 |
4 | 30100000 | 34.5 | 5120 | 64 qam | 4 |
5 | 49599966 | 35 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 5 | 0 |
2 | ATDMA | 0 | 0 | 7 | 0 |
3 | ATDMA | 0 | 0 | 3 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
5 | ATDMA | 0 | 0 | 2 | 0 |
on 28-04-2024 17:43
I assume that you're right near the VM cabinet (which explains the power levels). If the upstream noise isn't coming from micro-reflections in the drop point, then something in the cabinet is getting et. The technician should know what to check. Rain seems to be the simultaneous factor.
Fitting an attenuator of any sort won't fix this (sometimes they try to bring downstream power down when that isn't needed and if they fit a fat attenuator, it pushes up the upstream power and that still won't help. All notions of power 'sweet spots' are relevant only in perfect line conditions.
on 28-04-2024 17:57
Hi the cabinet is about 100 ,meters away I will post another photo its not that near, are u saying the tech shouldn't lower the power levels? The downstream stream is over 10dbmv
on 28-04-2024 18:03
You don't have any post-RS errors (is that still the case?) - so downstream is OK. The upstream power is commanded by the CMTS and set at the value it needs to read the upstream data. This can dynamically change at any time. If there is noise on the line, the QAM modulation will be changed by the CMTS.
When it rains, according to my understanding of your issue, the QAM modulation on upstream falls and you have a bad internet experience. So something is getting wet and causing noise ingress on the upstream.
Any neighbours with the same issue? A very useful piece of knowledge that would be.
28-04-2024 18:04 - edited 28-04-2024 18:08
Btw, wrt to your high power - you will have been placed on a low attenuation tap point at the cabinet. My sticky post on power level explains all that.
on 28-04-2024 18:06
