Loads of t3 timeouts too...
- madmanx11 months agoDialled in
More packet loss and loads of t3 timeouts still, upstream qam still on 16 on one of the channels..
Hi thing is if they send an engineer out I don't know what he or she can do apart from changing the cables etc, that's been done so I think it should be passed on to networks as I'm sure it's a problem in the network, I don't know if forum team can check my neighbours that are on virgin and see if they have same problems too?
- Ashleigh_C11 months agoForum Team
Thank you for updating madmanx
I have checked and I can see a few issues with the specs, we can get an engineer to come and take a look at this and if needed they can raise an order with our networking teams to take a look. First can I ask if you can perform a full factory reset as I can see the Hub has been up for over 2 weeks.
Just in case you aren't aware you can do this by pushing a pin etc into the rest hole and holding in for 30 seconds, this will cause a full reset so if you have changed any Hub details they will revert to the originals, but you can change these back afterwards.
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
