madmanx
11 months agoDialled in
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
Password | Show |
Router status
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 | 23600000 | 34.3 | 5120 | 16 qam | 5 |
2 | 36600000 | 34.5 | 5120 | 64 qam | 3 |
3 | 43100000 | 34.5 | 5120 | 64 qam | 2 |
4 | 30100005 | 34.3 | 5120 | 64 qam | 4 |
5 | 49600000 | 35 | 5120 | 64 qam | 1 |
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 | ATDMA | 0 | 0 | 20 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
5 | ATDMA | 0 | 0 | 4 | 0 |
madmanx
Welcome back!
Password | Show |
Router status
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 | 202750000 | 9.4 | 38 | 256 qam | 9 |
2 | 138750000 | 9.5 | 38 | 256 qam | 1 |
3 | 146750000 | 9.3 | 38 | 256 qam | 2 |
4 | 154750000 | 9.1 | 38 | 256 qam | 3 |
5 | 162750000 | 9.3 | 38 | 256 qam | 4 |
6 | 170750000 | 9.4 | 38 | 256 qam | 5 |
7 | 178750000 | 9.1 | 38 | 256 qam | 6 |
8 | 186750000 | 9.4 | 38 | 256 qam | 7 |
9 | 194750000 | 9.4 | 38 | 256 qam | 8 |
10 | 210750000 | 9.3 | 38 | 256 qam | 10 |
11 | 218750000 | 9.3 | 38 | 256 qam | 11 |
12 | 226750000 | 9.4 | 38 | 256 qam | 12 |
13 | 234750000 | 9.3 | 38 | 256 qam | 13 |
14 | 242750000 | 9 | 38 | 256 qam | 14 |
15 | 250750000 | 8.8 | 38 | 256 qam | 15 |
16 | 258750000 | 8.4 | 38 | 256 qam | 16 |
17 | 266750000 | 9 | 38 | 256 qam | 17 |
18 | 274750000 | 9.5 | 38 | 256 qam | 18 |
19 | 282750000 | 9.6 | 38 | 256 qam | 19 |
20 | 290750000 | 9.8 | 38 | 256 qam | 20 |
21 | 298750000 | 10.1 | 38 | 256 qam | 21 |
22 | 306750000 | 10 | 38 | 256 qam | 22 |
23 | 314750000 | 10 | 38 | 256 qam | 23 |
24 | 322750000 | 10.1 | 38 | 256 qam | 24 |
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 | Locked | 38.6 | 56 | 0 |
2 | Locked | 38.9 | 62 | 0 |
3 | Locked | 38.6 | 55 | 0 |
4 | Locked | 38.6 | 60 | 0 |
5 | Locked | 38.9 | 58 | 0 |
6 | Locked | 38.9 | 53 | 0 |
7 | Locked | 38.6 | 51 | 0 |
8 | Locked | 38.9 | 56 | 0 |
9 | Locked | 38.6 | 43 | 0 |
10 | Locked | 38.6 | 43 | 0 |
11 | Locked | 38.6 | 58 | 0 |
12 | Locked | 38.9 | 48 | 0 |
13 | Locked | 38.9 | 64 | 0 |
14 | Locked | 38.6 | 59 | 0 |
15 | Locked | 38.6 | 70 | 0 |
16 | Locked | 38.9 | 89 | 0 |
17 | Locked | 38.6 | 62 | 0 |
18 | Locked | 38.9 | 66 | 0 |
19 | Locked | 38.9 | 58 | 0 |
20 | Locked | 38.9 | 86 | 0 |
21 | Locked | 38.9 | 46 | 0 |
22 | Locked | 38.6 | 37 | 0 |
23 | Locked | 38.9 | 45 | 0 |
24 | Locked | 38.9 | 59 | 0 |
- madmanx11 months agoDialled in
- madmanx11 months agoDialled inWelcome back!Sign in to view or modify your Hub 3.0 settings.
Password Show Router statusNetwork Log
Time Priority Description21/03/2024 18:35:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 21/03/2024 11:51:28 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 19/03/2024 17:18:6 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 17/03/2024 23:51:27 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 14/03/2024 13:12:11 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 14/03/2024 11:51:27 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 11/03/2024 20:38:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 11/03/2024 12:44:44 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 07/03/2024 21:47:1 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 06/03/2024 21:58:10 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 04/03/2024 00:00:11 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 03/03/2024 18:20:42 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 29/02/2024 13:15:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 28/02/2024 12:35:39 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 23:29:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 21:44:35 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 08:09:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 01:58:52 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 01:58:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; 20/02/2024 01:58:48 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
