IpFreely knows what he is talking about and has taken a different tack from me. Totally valid. They send a tech to verify the obvious before calling Networks in (if you're lucky).
We haven't yet seen your photo as it has to be OK'd by one of the VM bods and that's pro;;y not gonna happen today. But yes, leverage with a screwdriver will open that box and you'll see if it's waterlogged. It shouldn't be if it's properly sealed. If it is waterlogged, you've got problems, in addition to what IpFreely has offered.
Hi seph can u see the photo now?
- Sephiroth10 months agoAlessandro Volta
Yes - that's the box to open up and see if it's waterlogged.
- madmanx10 months agoDialled in
Thanks seph I had a look at it don't know where to put the screwdriver to open it up I don't wanna break it but it's been raining today so will try tommorow.
You stick a thin screwdriver or a Bradall into the hole in the middle left of the picture. Or you go into an endge and prise it up. It will not break.
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
