madmanx
2 years agoDialled in
Hi I put the 10db forward path attenuator on and took the 6db one off but straight away I noticed that videos were freezing/lagging so I put the 6db one back on again, but now power levels are going over 10dbmv again, what do I do now? Can virgin send me a 10db attenuator or should I request an engineer to adjust the power levels in the cabinet? Also upstream levels were all at 64qam but now are playing up again, so much for upgrading our service.
madmanx
Welcome back!
Sign in to view or modify your Hub 3.0 settings.
Password | Show |
Router status
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 | 202750000 | 9 | 38 | 256 qam | 9 |
2 | 210750000 | 9 | 38 | 256 qam | 10 |
3 | 218750000 | 9.1 | 38 | 256 qam | 11 |
4 | 226750000 | 9.3 | 38 | 256 qam | 12 |
5 | 234750000 | 9.3 | 38 | 256 qam | 13 |
6 | 242750000 | 9.1 | 38 | 256 qam | 14 |
7 | 250750000 | 9.3 | 38 | 256 qam | 15 |
8 | 258750000 | 9.4 | 38 | 256 qam | 16 |
9 | 266750000 | 9.5 | 38 | 256 qam | 17 |
10 | 274750000 | 9.5 | 38 | 256 qam | 18 |
11 | 282750000 | 9.5 | 38 | 256 qam | 19 |
12 | 290750000 | 9.5 | 38 | 256 qam | 20 |
13 | 298750000 | 9.9 | 38 | 256 qam | 21 |
14 | 306750000 | 9.6 | 38 | 256 qam | 22 |
15 | 314750000 | 9.9 | 38 | 256 qam | 23 |
16 | 322750000 | 10 | 38 | 256 qam | 24 |
17 | 330750000 | 10.3 | 38 | 256 qam | 25 |
18 | 338750000 | 10.4 | 38 | 256 qam | 26 |
19 | 346750000 | 10.3 | 38 | 256 qam | 27 |
20 | 354750000 | 10.1 | 38 | 256 qam | 28 |
21 | 362750000 | 10.1 | 38 | 256 qam | 29 |
22 | 370750000 | 10.3 | 38 | 256 qam | 30 |
23 | 378750000 | 10.1 | 38 | 256 qam | 31 |
24 | 386750000 | 10 | 38 | 256 qam | 32 |
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 | Locked | 38.9 | 5 | 0 |
2 | Locked | 38.9 | 9 | 0 |
3 | Locked | 38.6 | 7 | 0 |
4 | Locked | 38.6 | 13 | 0 |
5 | Locked | 38.9 | 9 | 0 |
6 | Locked | 38.6 | 8 | 0 |
7 | Locked | 38.9 | 11 | 0 |
8 | Locked | 38.6 | 11 | 0 |
9 | Locked | 38.9 | 10 | 0 |
10 | Locked | 38.9 | 9 | 0 |
11 | Locked | 38.6 | 10 | 0 |
12 | Locked | 38.9 | 12 | 0 |
13 | Locked | 38.9 | 14 | 0 |
14 | Locked | 38.6 | 7 | 0 |
15 | Locked | 38.6 | 7 | 0 |
16 | Locked | 38.9 | 11 | 0 |
17 | Locked | 38.9 | 7 | 0 |
18 | Locked | 38.9 | 9 | 0 |
19 | Locked | 38.9 | 9 | 0 |
20 | Locked | 38.6 | 11 | 0 |
21 | Locked | 38.9 | 9 | 0 |
22 | Locked | 38.9 | 6 | 0 |
23 | Locked | 38.6 | 9 | 0 |
24 | Locked | 38.9 | 19 | 0 |
- madmanx2 years agoDialled inWelcome back!Sign in to view or modify your Hub 3.0 settings.
Password Show Router statusUpstream bonded channels
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 49599926 36.5 5120 64 qam 1 2 36600054 36.3 5120 64 qam 3 3 30100000 36 5120 64 qam 4 4 43100073 36.5 5120 64 qam 2 5 23600005 36 5120 32 qam 5 Upstream bonded channels
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 ATDMA 0 0 0 0 2 ATDMA 0 0 0 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0 5 ATDMA 0 0 3 0 - madmanx2 years agoDialled in
hi
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
