unisoft
2 years agoKnows their stuff
If you have rebooted and checked all connections are tight (blah blah) then you'll need a tech visit as your QAM levels are wrong on 4 upstream channels. They should all be 64QAM on a normal connection. Whilst they can work at lower levels, it normally means less bandwidth. The other figures are fine though unless you start having around 29db on upstream.
Related Content
- 8 months ago
- 7 months ago
- 2 months ago
