You can try the 10dB attenuator to see if that improves ( lowers ) the downstream power figures. You can even try both attenuators ... but look carefully at the outcome, -7 to +7 dBmV is the preferred range.
The upstream, remember the direction, this power level is showing how strongly the VM Hub is transmitting to the street cabinet. The real concern here is the channels are not all holding at QAM 64, suggesting there is an SNR issue in the locality. As the power levels are not high, the issue may be affecting everyone local to you.
- madmanx2 years agoDialled in
Hi I put the 10db forward path attenuator on and took the 6db one off but straight away I noticed that videos were freezing/lagging so I put the 6db one back on again, but now power levels are going over 10dbmv again, what do I do now? Can virgin send me a 10db attenuator or should I request an engineer to adjust the power levels in the cabinet? Also upstream levels were all at 64qam but now are playing up again, so much for upgrading our service.
- madmanx2 years agoDialled inWelcome back!Sign in to view or modify your Hub 3.0 settings.
Password Show Router statusDownstream bonded channels
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 202750000 9 38 256 qam 9 2 210750000 9 38 256 qam 10 3 218750000 9.1 38 256 qam 11 4 226750000 9.3 38 256 qam 12 5 234750000 9.3 38 256 qam 13 6 242750000 9.1 38 256 qam 14 7 250750000 9.3 38 256 qam 15 8 258750000 9.4 38 256 qam 16 9 266750000 9.5 38 256 qam 17 10 274750000 9.5 38 256 qam 18 11 282750000 9.5 38 256 qam 19 12 290750000 9.5 38 256 qam 20 13 298750000 9.9 38 256 qam 21 14 306750000 9.6 38 256 qam 22 15 314750000 9.9 38 256 qam 23 16 322750000 10 38 256 qam 24 17 330750000 10.3 38 256 qam 25 18 338750000 10.4 38 256 qam 26 19 346750000 10.3 38 256 qam 27 20 354750000 10.1 38 256 qam 28 21 362750000 10.1 38 256 qam 29 22 370750000 10.3 38 256 qam 30 23 378750000 10.1 38 256 qam 31 24 386750000 10 38 256 qam 32 Downstream bonded channels
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 Locked 38.9 5 0 2 Locked 38.9 9 0 3 Locked 38.6 7 0 4 Locked 38.6 13 0 5 Locked 38.9 9 0 6 Locked 38.6 8 0 7 Locked 38.9 11 0 8 Locked 38.6 11 0 9 Locked 38.9 10 0 10 Locked 38.9 9 0 11 Locked 38.6 10 0 12 Locked 38.9 12 0 13 Locked 38.9 14 0 14 Locked 38.6 7 0 15 Locked 38.6 7 0 16 Locked 38.9 11 0 17 Locked 38.9 7 0 18 Locked 38.9 9 0 19 Locked 38.9 9 0 20 Locked 38.6 11 0 21 Locked 38.9 9 0 22 Locked 38.9 6 0 23 Locked 38.6 9 0 24 Locked 38.9 19 0 - madmanx2 years agoDialled inWelcome back!Sign in to view or modify your Hub 3.0 settings.
Password Show Router statusUpstream bonded channels
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 49599926 36.5 5120 64 qam 1 2 36600054 36.3 5120 64 qam 3 3 30100000 36 5120 64 qam 4 4 43100073 36.5 5120 64 qam 2 5 23600005 36 5120 32 qam 5 Upstream bonded channels
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 ATDMA 0 0 0 0 2 ATDMA 0 0 0 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0 5 ATDMA 0 0 3 0
Related Content
- 8 months ago
- 7 months ago
- 3 months ago
