Thanks for replying seph, nice to see u back, so is the downstream power levels at 10.3 OK? I though? they have to be under 10? Also the upstream qam is behaving a little better now all on 64qam but they could change especially if it rains then it starts playing up again for reason? Is that normal? I've checked the cable connection outside my house where the drop cable connects to the cable that goes inside my house seems to be OK it is inside the brown omnibox, I don't know if the connection outside should have some waterproof tape on it ot not to keep it waterproof?
I rang virgin to change appointment as I can't do Monday and It won't let me change it but when it done its checks it said there is an intermittent problem with my connection?
Strange thing is is that the thinkbroadband quality monitor looks fine and the upstream qam seem fine apart from some t3 time outs so should I let technician Come to check connection? Or shall I cancel it If the connection seems ok? What do u recommend seph?
Password | Show |
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID1 | 23599975 | 34.5 | 5120 | 64 qam | 5 |
2 | 36600000 | 34.8 | 5120 | 64 qam | 3 |
3 | 30100000 | 34.5 | 5120 | 64 qam | 4 |
4 | 43100015 | 34.8 | 5120 | 64 qam | 2 |
5 | 49600000 | 35.3 | 5120 | 64 qam | 1 |
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
Related Content
- 8 months ago
- 7 months ago
- 2 months ago
