on 02-05-2023 20:46
Any help would be welcome.
I moved to virgin mobile a week ago.
The WiFi calling won’t seem to work. I’ve switched it on in my settings.
I’ve texted all to 78992 multiple times as per the help pages but I get a message saying not delivered each time.
Messages to other numbers send no problem.
TIA
on 02-05-2023 20:53
Hi @Gethin72
Thanks for your response
Sorry to hear about the issue with WiFi calling, has the feature ever worked on your handset previously?
on 02-05-2023 20:59
If you turn on airplane mode, then re-enable WiFi does it work?
on 02-05-2023 21:23
yes I was with O2 before and it worked fine.
on 02-05-2023 21:24
I gave it a go but unfortunately no change.
on 02-05-2023 21:54
Assuming Android, access the below and check if you see a WiFi calling option:
on 02-05-2023 22:07
sorry I should of said I’ve got an I phone (x)
thanks for posting all that info.
on 02-05-2023 22:12
We can no longer be friends... just kidding 😊.
It does sound like there is something wrong on the account side, rather than device.
I'll leave it to VM to discuss further.
on 02-05-2023 22:14
Good on ya.
on 03-05-2023 08:22
Hi there @Gethin72 thanks for your reply 😊 Sorry to see this is still not working.
I have checked our system and can see that this is something we'd need to discuss with you further via PM.
I'll pop you a message to confirm your details.
Nathan
