how to order wifi pods
rich700r
hi I've recently had virgin installed and the WiFi is none existent I'm my lads room I've looked but can seem to order the pods can anyone share any light on this thanks
2 REPLIES 2
Read this pinned thread Solved: How do I order the Wi-Fi pods? - Virgin Media Community - 5123613
The official route is to use the VM Connect app to scan the property and depending on the results, order one Pod initially.
However if you can't get that to work, just wait here a couple of days for a VM Mod to pick this up and discuss.
John_GS
Hi @rich700r
Thanks for posting, welcome to both Virgin Media and the community.
Sorry to hear of any WiFi issues.
John_GS
