Slow Upload speed
gazthomas
For the last couple of days my upload speed on both WiFi and ethernet have been down from the 50-55mps I ususlly get and should get to between 7-10mps.. I vw rebooted everything a number of times but no change
18 REPLIES 18
Lets see the connection data... can you do this..
______________________________________
Do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Disconnect all the connections and reconnect to be sure. Ensure there are no “unterminated cable loose ends or loose wires on the connectors . Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling (no clips piercing, or broken sheathing) and the wall box.
Then,
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
gazthomas
I will do this later but I am getting this low speed again tonight.. In the day it's been fine full upload speed over 50mps but come evening down to 6mps
David_Bn
Thanks for reaching out to us @gazthomas, and I'm sorry to hear of the slow upload speeds you've been experiencing on your connection.
Can you please confirm if you've been able to review the post from @jbrennand and offer us an update on the status of the upload speed on the connection?
David_Bn
Hi the issue is back again this evening having been fine all day I will provide the data a little later tonight.. Tje cables and connections are all OK this issue only happens during the late afternoon and evening..
13310000006.541QAM 25625
22110000007.642QAM 25610
32190000007.642QAM 25611
42270000007.442QAM 25612
52350000007.242QAM 25613
62430000006.941QAM 25614
72510000006.841QAM 25615
82590000006.941QAM 25616
92670000006.841QAM 25617
102750000006.641QAM 25618
112830000006.641QAM 25619
122910000006.841QAM 25620
132990000006.841QAM 25621
143070000006.641QAM 25622
153150000006.241QAM 25623
163230000006.341QAM 25624
173390000006.541QAM 25626
183470000006.541QAM 25627
193550000006.441QAM 25628
203630000006.641QAM 25629
213710000006.741QAM 25630
223790000006.441QAM 25631
233870000006.140QAM 25632
243950000006.341QAM 25633
254030000006.641QAM 25634
264110000006.140QAM 25635
274190000005.940QAM 25636
284270000005.840QAM 25637
294350000006.240QAM 25638
30443000000640QAM 25639
314510000005.640QAM 25640
3.0 Downstream channels
1Locked4185273590
2Locked425883290
3Locked427609800
4Locked4210820510
5Locked4212616660
6Locked4117294220
7Locked4121958970
8Locked4127184520
9Locked4132089590
10Locked4138775850
11Locked4145008030
12Locked4156487510
13Locked4158640130
14Locked4169299700
15Locked4179404460
16Locked4193169310
17Locked4194958460
18Locked4191264000
19Locked4197381640
20Locked41108726980
21Locked41125903150
22Locked41132768830
23Locked40160622190
24Locked41178718080
25Locked41204218640
26Locked40246628220
27Locked40234315940
28Locked40257735790
29Locked40274944130
30Locked40279516240
31Locked40316022680
3.0 Upstream channels
04960000041.35120QAM 641
143100000415120QAM 642
23660000040.85120QAM 643
33010000040.55120QAM 644
423600000405120QAM 645
0ATDMA0030
3ATDMA00350
4ATDMA0012840
09-12-2023 18:35:48criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:19noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:19warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:15noticeREGISTRATION COMPLETE - Waiting for Operational status
09-12-2023 02:59:09warningDynamic Range Window violation
09-12-2023 02:59:09warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:09warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:09warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:04noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:59:01noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:58:58warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:58:56noticeHonoring MDD; IP provisioning mode = IPv4
09-12-2023 02:58:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:58:34criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
09-12-2023 02:58:34criticalCable Modem Reboot because of - unknown
08-12-2023 19:33:30criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-12-2023 19:32:16criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-12-2023 19:31:43criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
08-12-2023 19:31:42criticalCable Modem Reboot because of - HW or Power-On Reset
06-12-2023 21:09:20criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
06-12-2023 21:09:19criticalCable Modem Reboot because of - HW or Power-On Reset
04-12-2023 18:32:22criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
04-12-2023 18:32:22critical16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-12-2023 19:13:42criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-12-2023 19:10:29criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-12-2023 19:09:59criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
03-12-2023 19:09:26criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
all done and pasted below - I am currently getting 12mps on ethernet connected PC - which all day has been giving me 55mps - this has now been happening for at least the last week - the download speed is fine - full speed
i have now posted the requested info above
