Strange hub3 behaviour
CJ38
I have separate SSID's for my wifi. One morning I found that I had no 5Ghz wifi. The 2.4 was working as was the direct connection to the hub. When I did the 192.168.0.1 to find out what was going on it said there was already a connection and I couldn't do a second one. I switched the hub off for a few minutes then switched on and everything was back to normal. So what do you think was going on there and should I be worried
1 ACCEPTED SOLUTION
Accepted Solutions
I can go with that thank you. That just leaves the question why did my 5GHz wifi stop working
6 REPLIES 6
 I suspect the Hub just needed a rest.   🙂
The power cycle just gave the Hub a "refresh".  I believe VM would recommend a power cycle once a week.  Nothing to worry about, unless of course it gets much worse.
Legend
Managing the Hub 3 via Wi-Fi is the cause of finding your last Hub 3 admin session still active.
To avoid this problem, 1) Only manage the Hub 3 via a wired network connection. 2) Always logout.
Just enough time for not coding the hub to renew DHCP and needing a reboot.😋
My hub has been on for 197 days and I once had it on for so long the uptime reset to 0 think its upto 512days when it reset
Yeap, my Hub (modem mode) only gets a reboot if there is a prolonged power outage.
Unless it falls over of it's own accord ......   😉
jpeg1
The Hub lockout one of the Hub's known features, to be enjoyed if you try to log in both ways.  Always use the ethernet connection and log out afterwards.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
