Red light hub 3
AndrewM7
Hi Zoie and Forum Team
I’m having the same issues with the Hub 3 that others have described: A permanent red light - and has been that way for a while.  I have tried resetting as suggested and on - off lots of times but no joy.  It works ok most of the time, but drops out a lot on calls and when streaming.  It is out of the light, has plenty of airflow and cables untouched since install.
Can you please replace my box with a more reliable one?
Thanks a lot
Andrew
[MOD EDIT: Post split to create own thread]
1 REPLY 1
John_GS
Hi @AndrewM7
I'll send you a PM now to get a tech out, it's more than likely a failing LED light.
John_GS
