Pre RS Errors Post RS Errors
nk3
Hello,
I am using Hub5 and noticed my internet connection struggles from from to time.
After initial investigation on router network status noticed Pre RS Errors Post RS Errors counts in Downstream channels, below is the log.
Can someone let me know is this the reason the internet connection struggles from time to time or its something else.
3.0 Downstream channels
1Locked419250
2Locked41570
3Locked41610
4Locked41590
5Locked41111233
6Locked41850
7Locked41142112
8Locked4220096
9Locked411850
10Locked41236147
11Locked41670
12Locked41108144
13Locked41850
14Locked41340152
15Locked414480
16Locked415190
17Locked41697163
18Locked41896162
19Locked411216166
20Locked4113900
21Locked412095180
22Locked4127890
23Locked412690127
24Locked4133790
25Locked4149590
26Locked4155170
27Locked416084127
28Locked416988109
29Locked41115940
30Locked4034686143
31Locked40331460
3.1 Downstream channels
39924K1800QAM 40961128
39Locked411.0352029360816
Regards,
N
1 REPLY 1
How exactly does it "struggle" ?  On ethernet cable connections as well as wifi ones ? Can you do this....
_________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and any T3 ones) you have a problem (noise) that only a Tech visit will sort.  Also check the Upstream QAM’s are all at 64
If they reappear - post up 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
