on 02-10-2023 23:19
I'm going round in circles here...
I have recently upgraded to the 1gig volt package.
I have set up the new hub 5 router and have good reception close to the Hub 5, but have poor WiFi in the kitchen at the back of the house.
In 'my virgin media' account it says to order from the VM connect app...
The VM connect app says go to 'my virgin media' account and order a WiFi pod?
The contact phone number rings out for ages....
How do I get one?
on 02-10-2023 23:32
The connect app didn't work with the hub 5, don't know if it's supposed to be fixed.
You can either call Virgin on 150 from a Virgin phone, mobile or landline, or 0345 454 1111 from any other phone to report a fault, or wait here for one of the forum team to pick this up which might be 2 to 3 day's.
When phoning choose the option to report a fault, then ignore all the options offered and you should then be placed into a queue to speak to someone.
on 03-10-2023 00:44
I would also like to add that the connect app used to work with my hub 3 then stopped working, error at Virgins end.
Tried all the Virgin suggestions, delete and reinstall, clear cache, reboot the hub, it used to work on both my phone and the OH's phone, since it stopped working both phones have been replaced and the connect app freshly installed and still get the same "Error at our end".
The message at the end "We can't find the hub" "we can only see your devices when connected to the hub"
Well it's connected to the hub that's how my phone generally works.
on 05-10-2023 10:55
Hi roy247,
Have you made any changes to your networks SSID's or passwords etc this can cause issues. Can you also send me a screenshot of the error message received and the devices used along with software details please?
It may not be related or the reason for your problems but there is an issue with iOS 17 and the connect app that is being looked into at present.
Rob
on 05-10-2023 20:58
Hi Rob,
Screenshot below is from my Xiaomi pad 5 running android obviously and everything is up to date. Same message all 3 devices, tablet and 2 phones, android 13. Suddenly stopped working before I replaced the previous 2 phones. Don't have an exact date because it's not something you need to use much.
I have made no changes to my hub settings between it working and not working, as I said hub has been rebooted and the app reinstalled.
on 08-10-2023 09:47
Hi roy247 👋
Thanks for posting a further update on this issue, as well as the screenshot. I'll ensure these are passed to our App Team, so we can look into this further. We are aware of an issue identical to yours that is affecting some devices, it is caused by an error in the data on one of our backend systems that our teams are investigating, so this may be linked.
I'm going to send you a private message, so we can look into ordering you a Pod. Please look out for my message in the top-right, white envelope or by tapping your profile picture, and then "Messages".
on 08-10-2023 11:54
Hi Reece,
Not received a PM but it's not me that wants to order a pod it's davethefish the original poster of this thread.
Thanks for the offer. 👍
Roy
on 10-10-2023 12:15
Hi roy247 👋
Apologies! I'd misread the initial post you and davethefish made. I've gone ahead and sent davethefish a private message, so we can assist them further.
Thanks for letting us know 🙂
4 weeks ago
@Reece_MH wrote:Hi roy247 👋
Hi forum team,
Is there any update on this from last October, I still get the same error message and it doesn't matter how many times I delete the app and then reinstall it.
3 weeks ago
Hi there @roy247
Thank you so much for posting and welcome back.
We are so sorry that you are still facing this issue, I have checked back but we are no longer aware of a wider issue effecting the app, I'm going to pop you a PM so we can take a closer look. Please keep an eye out for the envelope at the top of your screen alerting you to a new message.
