on 02-11-2023 13:18
Hi old post but is there any chance you can go into further detail as to how to made these changes please?
on 04-11-2023 13:25
Hi @everlastuk
Thanks for posting and welcome back to the community. Please make your own thread as it avoids any work being missed :).
There are a few requirements for the Pods to work with our Hubs:
• The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
• Channel Optimisation must be left on.
• The SSIDs must be the same and broadcast enabled.
• The SSID must be password protected.
• The Passphrases of the SSIDs must match.
As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
This link will help though if you do have any issues: https://www.virginmedia.com/help/setup/intelligentwifipod
Best wishes.
