Cables on front of house
Jace123
Can the virgin cables be removed from the front of our home?
Jaime
6 REPLIES 6
They can be removed - but best done by VM or it could introduce "noise" into the network which could affect your neighbour's connections
Are you a customer of VM?  If not.. do the cables also service other properties as well as yours (some photos would help).
What's the reason do you want them removed?
japitts
VM often take a position that removing their equipment could cause issues with future installs, and that unless there's a demonstrable H&S risk - they won't expend effort or resource doing so.
Photos would all help
Jace123
Is it possible for VM to contact me to remove these. I am not a customer & don't need these cables in the future.
japitts
Can you post some photos as per previous posts requesting them?
Hi Jace123,
I'm sorry to hear you're wanting to remove some cables. As mentioned above, we would only look to do this if there is a health and safety risk. In most cases, we would then perform the relevant work to make things safe and secure.
I can refer this over to an area manager but would need some information and pictures of the cables too.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
Thanks for your response. I've messaged you the info.
