on 03-04-2023 23:22
on 03-04-2023 23:56
on 04-04-2023 10:25
Try manually setting the PC's DNS servers to Google as a test. They are 8.8.8.8 and 8.8.4.4
on 06-04-2023 11:11
Hi maaya88 👋
Thanks for your post, and a warm welcome to our Community Forums.
I'm sorry to hear you're experiencing problems when connecting your computer to the Wi-Fi Pods. Have you been able to do the advice provided by legacy1 and Adduxi? Has this improved the connection? Are you able to provide the tracert log?
Are you seeing any lights on your Wi-Fi Pod when connecting to the device through an Ethernet cable? Are you able to try a different cable?
