2 weeks ago
Tested my PS5 with the new booster that I've received and Wifi is faster than wired significantly
75MBPS on wired with cat6 cable and over 200MBPS with wireless
I'm connected to the wifi 6 booster
Any advice?
We're on the 1gig package
2 weeks ago
Wired from the booster I assume?
Which booster is it (White or Black)?
Are you sure the PS5 isn't connecting directly to the HUB?
Sunday
I managed to sort out the wired issue which is now running fine but my issue now is the wireless is being capped at 450mbps
Sunday
It’s the black booster
Tuesday
Hi there @ethanfitzzz
Thank you so much for your post and welcome back to the community forums, it's great to have you here.
I am so sorry to hear that you have faced some issues with your wireless connections, can I ask if you can confirm your speeds are as expected via wired connections?
